Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Idler pulley lawn
I have a zts 7500 model craftsman 42" cut law mower. I need a idle pulley. Can't find it on the website
SOURCE: craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Posted on May 06, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Craftsman 20 HP 42
Did you obtain the correct replacement belt AND pulley. Double check your part numbers against the parts list for your machine. If you verify that they are correct, double check the belt routing, make sure it didn't get on the wrong side of a belt guide and is in the correct configuration. Look at your idler pulley and make sure the release spring is doing its job pulling it back from the applied position. Make sure that the arm for the pulley moves freely where it is bolted to the deck, it could be bound up with rust or debris. You should have a lot of slack in the belt when it is in the released position. If it does not then either it is the wrong part or improper installation
Posted on Sep 17, 2009
mowerman1857
  • 389 Answers
SOURCE: CRAFTSMAN Tractor Model%23 917257643 adjust idler
First things first! Before you installed the new belt, did you check the blades and idler pulleys to see if they all turned freely with no resistance while the belt was off and the blade brakes released? Release the blade brakes by engaging the handle with the engine off!
When you installed the new belt, did you put the back side of the belt against the flat pulleys and the inside of the belt in the V-pulleys? Did you double check to make sure you didn't inadvertently miss a belt guide getting the belt on the outside of it instead of underneath it. Did you look at the picture in your owners manual to make sure you had it routed correctly and make sure it is not rubbing against anything when you have the blade lever engaged? CHECK THIS WITH THE ENGINE OFF If you don't have your owners manual, look under the foot boards on the tractor, many of the Sears tractors have the routing diagrams there. If it is not there you can go to searspartsdirect.com , enter model number 917.257644 (NOTE the number difference) and look at the picture of the deck, it shows what the belt should look like when it is installed. You can also download an owners manual there. As best as I can remember, there is no adjustment for the idler pulleys.
Posted on Oct 25, 2009
Lawn mower blowing smoke
You are burning oil. This usually is from a leaky gasket. Go to ebay and find kiddie boutiques. They sell the best quality cheapest new tecumseh gaskets
Sep 27, 2014 | Garden
How o you change the lift assembly on a craftsman ZTS 7500 mower ?
Should be relatively simple. There are 4-5 cotter pins that connect the mowing deck to the bottom of the mower. Pull the pins, push the metal rods out, and remove the deck!
Jun 17, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
44" v-belt needs to be replaced
Look under footrest for diagram on sticker.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do you change Craftsman Lawn tractor model 917.272673 belt
it simple 1st lower mower deck 2nd take belt off of engine pulley then out behind the idler pulleys then the blade pulleys slide out & reinstall if i can further help you e-mail me wade at wadembly@aol.com
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman zts 7500 will not run with levers engaged
Cody,
Apr 05, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
