Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Safetron safe Door is open, need help to reset codes
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Posted on Oct 10, 2009
SOURCE: kingavon safe 28 door locked open, how do i
electronics not working can t find key need one but don t have any addresses or telephone numbers can anyone help
Posted on Oct 25, 2009
jyackle5
  • 8197 Answers
SOURCE: bought safe at thrift store.
May I get the make and model # of the safe to help you more
Posted on Apr 17, 2011
SOURCE: grafter electronic safe door open but in locked
default code for a grafter electronic digital safe.
Posted on Jun 20, 2011
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
I am locked out of my safetron Aanon home safe despitechanging batteries. What can I do?
It has defaulted back to the original code I expect. Try the original code.
Feb 13, 2017 | home Home Security
Do i need to keep the door open when i reset my Apple Safe Master YDB-AJ?
You may not need to have the door open when changing a code (many safes do not require this) but it is a certifiable insanity not to keep the door open when reprogramming any safe - electronic or mechanical.
If something goes wrong in the code changing process and you wind up with an unknown or scrambled with the door locked....well, use your imagination....
If the door is open at least you can call a professional to default it at best, or access the contents and junk the safe or lock at worst.
With most mechanical safes the door must be open in order to access the change code procedure, but electronic locks may not have that safety built in.
Also, don't attempt it without the manual for that model. And look for any section that talks about defaulting the codes before you start. And operate the lock with the new code a few times with the door open and check it works, before closing the door and trusting you have got it right.
I may be overly suspicious, but either your boss has no clue that this could be a poisoned chalice job, or he knows full well, and doesn't want the egg on his face!
good luck
Jan 20, 2017 | Home Security
Change code
If it is locked and the person you got it from didn't give you the existing code, you can't. We see this all the time. If there was a way to bypass the code to the safe, anyone could do it. They are called a 'safe' for a reason, the contents are safe once the door is closed and locked :-) The only way to get in is to take to a locksmith who will drill the door, open it and put a new door on it. This is not usually a cost effective open with a small locker type safe.
Nov 23, 2015 | Home Security
How do i re set electronic safe after changing batteries
open the safe door on the panel beside the hinges there should be a reset button, Press the button once the safe beeps, input your new code and press A or B when finished code is now reset. Make sure you check your new code with the door open. Just turn the lock, input the code press your A or B which ever you chose, the lock dial should open.
Feb 16, 2015 | Locks & Locksmithing
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
How do i change the code on the S-25EBF safe
I'm not familiar with that safe but here's a few to try. You'll need to open the safe first in any case after opening then first try simply entering another code, lock it (with the door open) and try to unlock it,. Next, there may be a reset button inside the safe on the door press, hold, release and try entering a new code this may also require you to enter the original code w/wo some type of access code. As a simpler method, with the door open and electronics exposed, remove the cover plate and batteries, wait at lease an hour and replace the batteries, this may also start you with a code such as 0000. Can you tell me where you purchased it? This may help a lot!
May 21, 2014 | Safe International Digital Electronic Safe...
Have a SURESAFE brand safe at work which have no instructions
Hi there all I have a SURESAFE electronic security safe MODEL-OWSAFE30ES
(1) To set your own code first on safe
(2) locate the red reset button on the hinge end of the door.
(3) Press the red button, which will illuminate the yellow light on the keypad.
(4) Now key in your new code (3 to 8 digits) and press A or B to end. Note you have 30 second to complete this step.
(5) Test your new code whilst the door is open. Safe will beep twice to confirm code has been entered correctly, and knob can be turned clockwise.
(6) Repeat process any time you wish to change your code.,
Hope this help
regards
rick
Dec 30, 2009 | Safe International Digital Electronic Safe...
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
Need to reset the electronic code to open the safe.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
66 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
