how do i use the bluetooth facility in Acer Aspire 4715Z? What are the steps to be followed for enabling it? I would like to transfer data to and from my fone via bluetooth..i have a sony ericcson K790i handset that is bluetooth enabled
just switch on the bluetooth first thru button located on the left side it will light up blue color then see the small icon on the right corner of taksbar right click and Open bluetooth settings and then select options tab and then check the allow the bluetooth devices to find this computer check box and then come out selecting OK
now try to send some file from phone or pda thru the sending option and then search the bluetooth devices in ur device u will see ur pc in the list just select do the pairing first use code 0 zero to pairup both devices put zero on both sides and then conection will be established now u can easily send data from both devices thru bluetooth
on phone switch on bluetooth option and also in settings make ur device visible to other devices to show up during pairing process once ur device is paired up and saved then u dont need to do it again and again
pls let me know if it helps or i can give u more detailed info on this pls rate me FIXYA for my help if u like
just turn on the wifi or bluetooth switch in both device. after select the data which you want to send,right click > send > via bluetooth > search device > select the device > next > give pass word.. eg.0. > next> send>
in mobile you can see accept option. just select it,give pass word that you will give in your computer... eg.0 > and accept.
I am looking for a TRUE desktop-replacement.
I am looking for a quad-core min 4. GB of DDR3...
(More)
I am looking for a quad-core min 4. GB of DDR3 RAM.
I also want a better GPU then just the intregrated one so that I can truely play games hi-res, just search me the best laptop you can find, but not from dell, that includes Alienware.
Thanks in advance
i have dell vostro 1500 but i cant install any window if it is not register its need admin password...
(More)
i have dell vostro 1500 but i cant install any window if it is not register its need admin password in order to use setup plz helpppppppppp
