Reset lg hr400 br app
Reset lg hr400 br
Hi, how can i reset my LG p525 with buttons???
Hard Reset (Factory Reset)
If you forget your lock sequence and backup PIN, you will have to perform a hard reset to gain access to your phone.
WARNING!
Performing a hard reset deletes all of your user data, which includes pictures, videos, and music saved to your internal memory. Please make sure to back up your information prior to performing a hard reset.
Turn the phone off.
Press and hold the following keys at the same time: Volume Down Key + Power/Lock Key on the back of the phone.
Release the Power/Lock Key only when the LG logo is displayed, then immediately press and hold the Power/Lock Key again.
Release all keys when the Factory hard reset screen is displayed.
Press the Power/Lock Key to continue or either of the Volume Keys to cancel.
Press the Power/Lock Key once more to confirm or either of the Volume Keys to cancel.
Apr 05, 2017 | LG Cell Phones
My lock screen on galaxy 5 won't come on. It goes straight to home screen. Why is it doing that? It was fine 2 days ago. How can I get it back?
Three Reasons Why Screen Lock is Gone
1. Screen Lock has been deactivated (Instructions how to activate are at bottom.)
2. Android Screen Security File may have been deleted, and screen lock option is no longer on your devise.(A Factory Reset will restore original Android files)
3. Malfunction Somewhere in Samsung Phone. (A Factory Reset might work, but not guaranteed)
(How to Factory Reset phone at bottom.)
How to ativate Screen Lock and Security settings
1. Press the apps icon, it usually at the bottom of screen.
2. Find Settings and press that button to open settings menu.
4. Scroll down the menu to Lock Screen and Security, press that to open options menu.
5. The first option at top is Screen Lock Type.Press and Open.
6. You will have 3 lock types to choose from. Swipe Lock, Passcode Lock, Password Lock
(advise, do not forget password, only a hard phone reset, or an apk lockout file will get you back in)
If activating screen lock through settings did not work, or if option is not available, you can try to reset phone to the way it was when you bought it.
There is a couple things you should know.
1. contacts, photos, videos, downloaded apps, games, and everything not on the phone when it was first bought, or when you first got the phone will be erased.
2. You can back up contacts, photos, videos, in settings menu, scroll down to Backup and Reset. Or save to an sd card, and remove sd card before applying reset option
3. If you have an account (google or android email) associated with your phone, you will need email address, (example@any.com) and password to get back in phone after phone resets and turns on.) Dont remember password, Please create a new password now before continuing to reset to manufacture settings.
Reset Phone to Manufacture Settings
1. Remove SD Card, or its saved files will be erased.
2. Open apps, Open Settings Menu, Scroll Down to Backup and Reset.
3. Scroll down to bottom of page to Factory Data Reset.
4. Follow instructions to reset phone.
When your phone comes back on, Swipe Screen Unlock should be active at phone turn on, if screen lock is not showing try again to turn on in security settings.
If still does not work,
I am sorry, Your phone has permanantly malfunctioned. You can try your phone store, or a phone repair shop.
Mar 10, 2017 | Samsung Galaxy Cell Phones
My camera says it is in use by another app. How do i find which app is using it
Off course your camer is NOT in use by any other app. It has some software conflict.
Turn your tablet off, completely. If still you get the warning after restarting, reset your tablet
Nov 08, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
How do i get my tablet out of safemode?
Restart your device by holding the power button, then tap Power off.Tap Ok to confirm.Power the device on. Your tablet should now be out of safe mode.If the device is still in safe mode use one of the following methods.
Uninstall the last application you installed: From the Apps menu, tap on Settings.Tap on the app and then tap on Uninstall.Restart your device. (Next step is if the above last uninstalled app/s did not work.) Perform a factory data reset:From the Apps menu, tap on Settings, and then tap Backup & reset.Tap on Factory Data Reset, and then tap Reset Tablet.Tap Erase Everything to format your tablet back to factory default configuration.
Usually this happens if an uncompatible app or mod was installed. System boot up file misconfigured or uncompatible with recent install, but get rid of that recent install and all should work. I hope this helps, good luck.
Sep 19, 2015 | Computers & Internet
How to reset to factoy..All it does is talk cant get to settings
Do a google search for terms
Factory Reset, LG and the model
You might get some manual like this one where the procedure is indicated
http://images.comparecellular.com/phones/862/lg-globus-tu330-user-guide.pdf
Aug 24, 2015 | LG Cell Phones
What hotspot app will work with a lg 4g lte that was a verizon but is now straight talk
WHAT DO YOU MEAN BY A "HOTSPOT APP". A hotspot by definition a site where you can get free internet signal. Normally it's a public service.
You don't need any app to get internet signal when you connect your smatphone in a hotspot.
If you have a "liberated" LG 4g lte, you can get service from any cell phone provider, presuming it has legal origin and it's not blacklisted.
Aug 09, 2015 | LG Cell Phones
Have A 5.0 Studio Blue android phone&my volume is not working on when receiving calls but works on everything else&volume is up in settings,any suggestions?Factory reset erases my apps correct?
I don't believe you need to do a factory reset, Probably the phone call voulme has a different setting control. Check your phones manual for indications. In my LG phone the volume of multimedia (audio and video files) has nothing to do with the phone call volume.
Jun 22, 2015 | Android Cell Phones
When i try to downloan apps from marketplace it say i do not have an android device registered, how do i fex that
Where are you downloading apps from, the phone/tablet or on a PC? Have you setup a gmail account on your phone yet? A gmail account is required to register the phone/tablet on the android market.
Nov 22, 2011 | Google Android
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
