Question about Superior Canyon Creek Wooden Playset
Colorado wooden play set - Superior Canyon Creek Wooden Playset
2004 chevy colorado throttlle body relearn
I haven't done a throttle relearn. All I have done are plug and play. Ecm controls the throttle thru the pedal position sensor. I've done up to 2010 so far, on various makes and models.
Oct 11, 2014 | 2004 Chevrolet Colorado
New Colorado gr 2.8. Have a DP chip from Challanger that can be reprogramed to suit Colorado. Will Colorado benifit with the chip or good enough without it. Going touring pulling a 1800kg caravan.
playing with chips then pulling a load over a distance would be asking for trouble . I suggest that you take the car and the chips to a speed shop that has a chassis dyno and have the ECM set properly to give maximum power and economy.. IT may cost a few dollars but that will be cheap compared to engine troubles on a trip.
Mar 21, 2014 | Holden LX Cars & Trucks
Repairing holes in wooden doors
Depending on size beleive it or not BONDO (used for auto body repairs) works great, you can play around with it and add texture or make it smooth by sanding, you can even use course sand paper to give it wood grain look. :)
Aug 07, 2012 | Furniture
Are there any wooden darts for sale?
You don't see wooden darts around very often butthey are actually a lot of fun to play with. You can get them at: http://www.americanstyledarts.com/widdy-darts.htmlthey also have three flights.
Jul 09, 2012 | Sport & Outdoor - Others
I need instructions for circo wooden play kitchen set
go to www.kidcraft.com and select assembly instructions...many to choose from!!
Dec 23, 2011 | Toys
Wooden Blocks Toys problems
When first choosing a toy for a child, it is best to determine if the toy is age appropriate. The toy packaging usually has age recommendations. Companies take the time to research and test their toys before they put them out on the market. It is always best to monitor your child, especially a toddler, with any toy. Kids seem to have the knack for finding a weak spot with things whether they want to or not. Best rule of thumb is if a toy is smaller than the palm of your childs hand or if it can fit in their mouth, don't let them play with it. Children are special gifts. Let's protect them at all costs. Good luck.
Oct 26, 2009 | Heros Wooden Toys Building Blocks, 100...
Wrong time on the Dual Clock feature.
if your friend's does the same thing, than it's a problem with the signals being sent to the phone, whoever desiged that feature was WRONG haha
Sep 21, 2008 | LG enV VX9900 Cellular Phone
Replace brake pads on chev. colorado pick-up
90% of the time the sequence is identical.
Slacken wheelnuts.
Jack up and support on axle stand.
Remove roadwheel.
There should be two bolts holding the brake caliper on - usually on the inside.
Slacken both, but only remove the lower one.
The caliper should then be able to swing up pivoting on the top bolt.
You can remove this top bolt, but support the weight of the assembly with wire to the suspension spring - so as not to stress the brake hose.
Remove the brake pads, and clean the areas the pads seat on.
Push back the pistons. Some require a special tool, most make do with a wooden packer and suitable large lever - or G clamp.
Fit new pads. Pay particular attention to any fitting clips, springs, rods or pins that are needed.
With new pads in, swing down caliper into position. Fit new attatchment bolts or use a threadlock on fixings. & tighten.
Still with wheel off, depress brake pedal to activate brakes - & check for leaks and working.
With foot off brake, check hub turns with no problems.
Refit wheel and repeat for other side.
ALWAYS replace brakes in axle pairs.
Hope this helps.
Jun 14, 2008 | 2006 Chevrolet Colorado
Superior Canyon Creek Wooden Playset Logo
146 people viewed this question
Top Superior Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Superior Toy Expert? Answer questions, earn points and help others
