Question about TheraPure
Therapure spa does not stay inflated - TheraPure
  • 2,760 Answers
1st ck to see that your inflation valves are staying closed , this is a safety feature , that prevents over inflation and over rowdy behavior while inside tub
valves have a lock over cap that should be tightly closed
If this is good , start at bottom and work your way all over skin of tub with a wet paper towel with a bit of soap on it , bubbles will appear at hole(s) yes there can be more than one
common sites to really look at for holes are (entire bottom, top edge where one enters tub frequently, around hose fittings
) holes can be patched with std pool patches or use kit that came with tub
Posted on Jun 08, 2015
Do the heat and filter on an intex pure spa hit tub need to run continually together? I would like to put a timer on the filter.
read the manual but generally yes as if there is no flow then the heater element will over heat , boil and burn out
Mar 18, 2018 | Therapure Four Person Inflatable Round Hot...
How do I deflate spa
To deflate the portable Therapure spa 050006 is easy. The trick is to realize that the black valve used to inflate is in fact a double valve. Remove the square threaded cap to inflate it.
1. To deflate the spa leave the black square threaded cap and below that you should find a round or winged coupler.
2. Unscrew this coupler off and immediately the air will start to escape. It shouldn't take more than about 2 minutes to deflate and you are ready to pack it away.
3. Return the valve (before doing so you could use a vacuum to suck out as much air as possible.)
4. Lay out the spa floor in a circle
5. Fold the three sides to the centre
6. Then lay the power unit on the folded sides.
7. Remove the coupler one more time to squeeze out any remaining air and then return it.
8. Roll the up the side to the original size of the spa before you opened it the first time.
Sep 18, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
How to change a heating element in therapure spa?
I don't think you have a heater element?
It might be heating by kinetic energy/heat exchanger/heat transfer by the operation of the pump motor?
Jul 16, 2014 | Therapure Four Person Inflatable Round Hot...
Therapure est5868 wont heat and can not find heating element
I also have a Therapure EST5868 and the heating element must be done as the temperature does not rise above 17. I can't seem to find any information on the location of the element. Just wondering if anyone could help.
Mar 07, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
HOW TO DEFLATE THERAPURE SPA
fastest way is use a wet/dry shop vac , just place the tip of hose over inflation valve and it will draw air from walls (fast!!)
careful if using a home vac system , as some water might be inside walls and home vacs don't like that too much , wet/dry shop vacs are best 4 this
Dec 21, 2013 | Therapure Four Person Inflatable Round Hot...
How do you deflate a portable spa
Nov 23, 2013 | Therapure Pool & Spa
My Therapure four person inflatable suddenly stopped working. electrician says outlet and breaker are fine. I can get the plug to blink red but then it throws my breaker. no luck with 1 800 #
It is more than likely your heating element. Not sure what style they use but if you send me a pic of your equipment, spa pack w/ the cover removed, I can walk you thru how to test it.
If you have a good grasp of electricity, find the heating element and with the power off remove the leads. Try to plug it back in, reset the gfci, and give it a minute. If it doens't trip and everything runs fine replace the heating element. With most spa packs it is possible to replace only the element, some like watkins you have to replace the whole heater. If the spa still trips with the heater disconnected start unplugging your equipment starting with the ozone, then blower, then pumps, one at a time until your braker stays on.
Oct 18, 2013 | Therapure Four Person Inflatable Round Hot...
How do I deflate the spa?
the fastest way to deflate any inflated spa is 1st drain water away , then using a shop vac suck the air from the chambers , it takes but a few minutes to complete that way
take that from guy that's allways in a hurry !!
Sep 20, 2013 | Therapure Four Person Inflatable Round Hot...
TheraPure Logo
600 people viewed this question
Top Therapure Pool & Spa Experts
Raymond Richards
Raymond Richards
David Harrelson
David Harrelson
Tom Chichester
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
