Question about Garden
Rod spring bypass reconnect
Husqvarna 46 in cut
5 Suggested Answers
  • 7 Answers
SOURCE: my husqvarna 46 in. cut back fires when i turn it
The throttle is to high.... lower it down to an area between slow and medium and let it idle for a few seconds. That should stop the backfire.
Posted on Aug 27, 2010
  • 14 Answers
SOURCE: Husqvarna Riding Lawn Mower 46 Cut model
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Posted on Jul 17, 2011
richroth
  • 9472 Answers
SOURCE: i need to know where the rod arm bypass goes on a
Are you referring to the "tension rod" on the mower deck? I think the rod you are talking about is number 114 on the diagram. Take a look at this diagram.
Posted on Oct 01, 2011
richroth
  • 9472 Answers
SOURCE: where does the rod arm bypass go and what does it
I am not sure of your problem.
Posted on Oct 24, 2011
Engine will not start but solenoid grinds
SOLENOID DOES NOT GRIND FOR IS NO A MOBIL DEVICE, IT MIGHT BE THE STARTER WHAT IS NOT WORKING, SPECIFICALLY THE ACTUATOR THAT MIGHT BE STUCK, DISMOUNT STARTER AND CHECK SPRING AND GREASE THE SHAFT NO TO MUCH.
Sep 05, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Installing push rod
last time i check, i dont remember a spring connecting to a push rod. usually a push rod slides into the push rod galley until it hits the valve tappet.
Oct 20, 2013 | Husqvarna Garden
How to place freewheel control into engaged position
there is a rod that hangs out above the hitch you pull it out and move it into a released position when done release and push it in
Jul 01, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I need to know where the rod arm bypass goes on a husqvarna
Oct 01, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Is there a way to tighten the deck belt? i have gone through 2 belts and they dont seem to be tight around the pulleys.
Your deck should have a couple "idler" pulleys on them in addition to the main mandrell pulleys that have tension on them via springs to keep tension on your deck belt. Maybe you need to really examine the condition of those "idler" pulleys and also the main pulleys to find the problem.
Sep 10, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a yardman 46 in cut riding mower, it is leaving grass in the middle. I have put new blades, change the belts, put on a new tention spring, so what is my problem?
Well one of the spindle assemblies, could be running a little slower on one side then the other. But I would take a guess that you are trying to cut grass, way too fast for the mower. Try running a ground speed a liitle slower and see what happens.
Good Day.
Oct 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
May 01, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
