Question about Microsoft Xbox 360 Console
Xbox 360 games
3 red light
  • 4 Answers
And if you do try to fix it yourself, or you've voided the warranty ( by already opening it) make sure you DON"T do the " towel Fix " it will only make things worse. you need to do an X Clamp repair. It's simple. I had no experiance whatsoever.with electronics. and I was able to figure it out the first time I tried it. I did it three weeks ago and my X box is quieter than ever and it works fine. so serach on you tube " X Box 360 X clamp fix " and you should see what you need to fix your problem.
Posted on Feb 05, 2008
Clean all of the dust out from around the fan vents on the back of the xbox, blow out all of the connectors with a can of compressed air ( bought at most electronics retailers) , and if that doesnt work contact microsoft
Posted on Oct 31, 2012
    Problem Solver:
  • 7 Answers
Hello monu manat, Do not try to fix it yourself!!!!!! Microsoft has extended the warranty on all Xbox 360 consoles.The new warranty covers new and previously purchased Xbox 360s for three years, for the three flashing red light error only. So, if you get 3 red lights (a.k.a. RROD, three red lights, circle of doom, etc.) hardware error, you?re covered don?t try to fix it, don?t open the box. Send it back for free repair. Here are the full details: Xbox 360 Warranty and Service Enhancements :http://www.xbox.com/en-US/support/systemuse/xbox360/resources/warrantyupdate.htm Here is the new warranty FAQ : Xbox 360 New Warranty FAQ:http://www.xbox.com/en-US/support/systemuse/xbox360/resources/warrantyfaq.htm hop this will fix your problem. best regards AMINE
Posted on Aug 27, 2007
4 Suggested Answers
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
  • 34 Answers
SOURCE: xbox 360 red light
Unfortunately there is nothing that you can directly do to fix this problem without voiding your warranty,. This means that if you attempt to repair it and fail MS will not fix it for you.. The "Fix" posted by others SOMETIMES works, but NOT ALWAYS.
Pleae be careful with your expesive gear!
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
  • 13 Answers
SOURCE: xbox 360
I just fixed my Xbox360 3 RROD error by removing the heat sinks and reflowing the solder on both the CPU and GPU by using a heat gun and aluminum foil.
1. Remove the XClips and heatsinks.
2. Get some foil and press it around the GPU and CPU chips. This is to protect other SMT devices from getting blown away when the solder melts. I covered about half the PCB surrounding the chips.
3. Cut out a square hole for the chip you are working on, I used my fingernail. Give about an 1/16 inch gap all around the chip for heat to get under the chip but not on the caps etc on the PC board.
4. Run the heat gun all around the edges of the chip, trying not to overheat the silicon chip itself or the caps and resistors on the chip.
5. While heating the chip, I used a thin piece of solder near the chip to guage when it was hot enough to flow the solder (dont let this piece get onto anything when it melts) move all around the edges, aiming at a 45 degree angle into the chip.
6. Clean off the old heat sink compound off of the chips and heatsink and replace.
7. Reassemble the heatsinks, put the XClips back on (no I did not modify anything).
8, To do a quick test, plug in the power switch PCB, the fans, video and power. See if it works, shut it off as soon as you get the spinning green lights (it will overheat quickly without proper cooling giving the two vertical red light error).
Posted on Oct 24, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My 360 have 3 red light how to fix it
i hate to say this but......
i don't think u can.i think this is known as the "3 red lights of death" (search up xbox 360 3 red lights of death)
hopfully ur still under warranty.
Oct 25, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: my xboxs 360 has three red lights flashing...
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
May 17, 2010 | Microsoft Xbox 360 Console
My xbox has a red ring and wont turn on this is my second 1 in 3 years.
Go to this link it gives you many options to resolve your xbox red light issue.
Dont forget to rate me here in fix it,
thanks
http://forums.techguy.org/games/769776-xbox-360-3-red-lights.html
Feb 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : mahboobidrishi@hotmail.com
Website : http://sonyservice.en.china.cn/
Jan 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 3 red lights can anyone please help?
That has absolutely nothing to do with the Hard drive. The red ring of death is a standard misfunction with the Xbox 360. You will have to contact your local game stores to see if they do Red ring of death fixes, send it in to microsoft, or attempt to red ring fix it yourself.
Dec 12, 2008 | Microsoft Xbox 360 Console
Flashing 3 red lights
The 3 flashing lights suggests that it's a hardware problem and you'll have to send your 360 to Microsoft for repair. Go on xbox.com and there is a link for repairs.
May 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
299 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
