Question about Hitachi CP-S335 Multimedia Projector
Filter NJ22222 Whe I went to clean the filter the foam just crumbled and fell out. I need the little plastic foam filter insert.
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: I need the foam filter element only for A Hitachi CP-X200 LCD projector
AIR FILTER FOR HITACHI PROJECTOR CP X200 CP X300 CP X205 CP X305 CP X308...
Air Filter FOR HITACHI PROJECTOR CP X200 CP X205 CP X300 CP X305 CP X308...
Posted on Jul 11, 2015
Testimonial: "Thank you all for your quick response."
The prefilter fell apart and went down the funnel on the air box on a 1997 ski-doo touring le
i would remove all particles
and replace the filter
if it is a foam filter i would not worry to much and see what happens
there is a good chance they will be blown out the exhaust
if it was a metal filter
i would take out the spark plug and get a long reach telescopic magnet
and go all over your pistons with it to remove all metal fragments with it
hopefully that should be ok
or its a top end strip at least
Feb 12, 2014 | 1997 Yamaha Vmax Xtc, V-max Xtc, 600,...
N2000 clean filter
The red guard goes on top of the foam after it is installed. The purpose of the red guard is to keep the bag from sucking down against the filter when you get a few inches of dirt in the bottom of the bag. If it sucks down against the filter the dirt in the bag will cause an airlfow restriction even though the bag is not full.
Jan 25, 2014 | Riccar Vacuums
I purchased a Dyson DC05 cleaner from a garage sale.The suction is great,however I noticed that the debris does not swirl around in the cylinder when I am vacuuming.I think the suction could be even...
Hi there VacuumGuru from Vacuumspot.com.au here. You will find there are 2 reasons will not spin in a dyson DC05. 1 is that it is missing one of the 2 parts in the dust container, there should be an upside down funnel in there and a rubber boot on it. Without those dust just goes either to the bottom of the bin or to the filter. The 2nd cause is that even though the filters have been cleaned they are simply too old. When you hold the washable filter (the one with the plastic outer and the foam insert) up to the light and take out the foam bit you should be able to see light through the filter. If not you are probably only running on maybe 80% suction which still works but isn't as good as it could be.
The filters are available here if you need them.
Hope this helps! :)
Oct 06, 2010 | Dyson DC05 Cylinder Bagless Canister...
How to change air filter for 2007 volkswagen jetta ,2.5
Hi, on the VW Jetta 2006 to 2009, the cabin filter is underneath the glove box so lay down on the floor and look under to see the 2 plastic screws. Access is gained by removing two plastic screws and gently pulling down a piece of foam insulation. Once the insulation is removed you can see the filter 8 inch long by 2 inch wide black plastic face plate. You must slide the face plate toward the passenger side door.
The face plate will now come off and the filter will still be inside and you will have to pull it down. Debris will come out onto the floor mat below. Insert the new cabin filter, put the face plate back up an slide toward he drivers side to lock in place. Replace the insulation, re-screw the 2 screws, and you're back in business with fresh air and clean hands besides!
Take care
Aug 10, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
How do i clean my air filter wr 400
remove the side cover
undo the nut in the middle and remove filter
take the foam of the frame
clean with a solvent, kero or similar
clean again in detergent and water
continue until spotless
let dry
use a air cleaner oil from a bike shop
put some oil on the foam and squeeze until oil is completly over filter( will be all the same color)
can do this inside a plastic bag to save the mess
fit back on frame
place a smear of grease around the edge that has to seal.
refit in air box, with centre bolt
feel all the way around to make sure it is sealing.
refit side cover.
doesnt matter too much if it is still a little wet
do this after every dusty ride
even twice on very dusty rides
I keep about 3-4 spare filters, clean in plastic bags, and wash them all together.
dont forget oil changes as well, they hold a bit over 1 litre, so change it often
Jun 16, 2010 | 2000 Yamaha WR 400 F
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
How to change an air filter on a 2008 jetta 2.0 turbo
On the VW Jetta MkV, the cabin filter is underneath the glove box. Access is gained by removing two plastic screws, gently pulling down a piece of foam insulation, and releasing a single clip to detach the filter. It (and some debris from it) fall easily onto the floor mat below. Insert the new cabin filter, replace the insulation, re-screw the screws, and within 3 minutes, you're back in business with fresh air and clean hands besides!
Oct 03, 2009 | 2008 Volkswagen Jetta
Very little suction in hose no tears in hose
Hi there, SmartAlec from NelsonVacuums.com.au . I have fixed hundreds of Dyson DC07 vacuum cleaners over the last few years and i would say there are 2 possible causes for the loss of suction.
1st is that the filter looks clean but is actually worn anyway. The way to tell is remove the washable filter from your vacuum cleaner. Take out the foam insert this seems to last longer that the other part. Hold up the plastic cage to the light and look at the white part (well it used to be white anyway) you should be able to see light through it. If you cant see through it you need to replace it. Here is a link to that filter for purchase . To verify this is the problem just run the vacuum without the filter in you should see an improvement - note do not actually **** up material the filter is there for a good reason.
2nd problem is that you have a blockage in your radix assembly. If you take off the whole dirt bin and feel the suction on the upright part where the chamber joins the vacuum (basically bypassing the radix) if there is good suction here you will either need to replace the cyclone top or dismantle and clean it. (it is very difficult to clean as it doesn't completely dissassemble)
Hope this helps - If you want more help send me a message
HAPPY VACUUMING ! :)
Aug 24, 2009 | Dyson Vacuums
Filters
Okay simple. You should have 3 filters. A foam, plastic and a round paperish filter. Foam filter goes around black air filter which goes in the bottom removable tank and then the grey one goes in the upper tank and twists in
Dec 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Hitachi CP-S335 Multimedia Projector Logo
29 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
