Question about Continental Electric Portable Air Conditioner
Mobile air conditional CE14106
Need manual
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Arctic manuals
Mobile air condition...WOW...just drive faster and the cooler it gets!!
Need more info!
Jul 09, 2014 | ATVs
Operations Manual For Mobile A/C Modle:KYD-25/b
Dear FixYa,
I have an air conditioning Home Pride, Model KYD-25/b and have a problem in Cool mode.
It never got below 90 F, even I set to 65F. The compressor ran for a short time then stop, while the fan kept running. It cycled like that every 5 minutes or so.
Do I have a low refrigerant and need to charge? How do I do it?
Thank you.
Hao lam
hlam1@comcast.net
May 27, 2011 | Home Pride Heating & Cooling
I need download the user guide of Mitsubishi rkn502a remote control
Search Results
    [PDF]user's manual mitsubishi daiya room air ... - 3D Air Sales Ltd
    www.3dair.co.uk/DOWNLOADS...manuals/O&M%20RAC%20-%20SR...
    MITSUBISHI DAIYA ... performance, read and follow this User's Manual carefully before using your air condi- ... Operation and indication section for remote control . ....Symbols which appear frequently in the text have the following meaning:.
    Air Conditioning User Manuals - Mitsubishi Electric Australia
    www.mitsubishielectric.com.au/Air_Conditioning_Use...
    Mitsubishi ElectricUser Manuals/instruction booklets (including remote control instructions) forMitsubishi Electric Air Conditioners. ... Air Conditioning Downloads ยท Residential Air ...Need to know how to operate a Mitsubishi Electric air conditioning system?
    Remote Control Symbols - Mitsubishi Electric
Aug 20, 2010 | Heating & Cooling
Installation air conditionning in a window
If this is the Danby 8003 you mentioned, here's a link to the unit's manual. That should get you what you need. Good Luck!
http://www.retrevo.com/support/Danby-DAC8003D-Air-Conditioners-manual/id/886bh629/t/2/
May 27, 2010 | Danby DAC8003D Air Conditioner
Locate manual for a challenge air conditioning unit
Check out fixya .com for a manual of your choie.
Dec 17, 2009 | Heating & Cooling
MY UNIT IS CREATING ALOT OF CONDENSATION. I HAVE TRIED SO MANY WAYS TO FIX THE PROBLEM. THIS UNIT IS INSTALLED IN A MOBILE HOME. I HAVE OWN THE MOBILE HOME FOR 6 YEARS. HELP!!!!
Air conditioners are SUPPOSED to make condensation. Lots of water means lots of good air conditioning :-)
Do not fix it. It is not broken.
Jul 27, 2008 | Coleman Heating & Cooling
Continental Electric Portable Air Conditioner Logo
53 people viewed this question
Top Continental Heating & Cooling Experts
Shawn DuRee
Tim Whalen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
