Question about Microwave Ovens
Belling microwave SJ17SS - Microwave Ovens
Where can I get hold of a Belling BEL GT17SS microwave foot?
Temporarily, you can use a wine-bottle cork, cut to size. Mind your fingers!
Feb 13, 2015 | Belling Microwave Ovens
How to defrost in belling microwave oven del stw25 ?
Visit the companies web site and download the manual.
Sep 16, 2014 | Belling Microwave Ovens
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
MANUAL FOR BELLING MICROWAVE
There are so many models.
The link would be :-
http://diplofix.com/forum/manual%20for%20belling%20microwave
Put the model number and download.
If not available, let me know.
Thanks.
Jun 18, 2009 | Microwave Ovens
Instruction manual for Belling Combi oven BEL-CJSS25
Did you try this?
Lines are open Monday to Friday 8am - 6pm and Sunday 10am - 2pm.
Belling Customer Care: 0871 22 22 503
Or maybe this?
Belling Product Helpline
0871 22 22 635
Product Helpline Open Times
Monday to Thursday
9am - 5pm
Friday
9am - 4.30pm
Spare Parts
0871 22 22 506
Nov 24, 2008 | Belling Microwave Ovens
Belling microwave
Turn table motor open circuit/drive shaft damaged
Oct 18, 2008 | Belling Microwave Ovens
Cut out during heating
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Jul 16, 2007 | Belling BIM60 Microwave Oven
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
