Question about Refrigerators
Kenmore 363.9751510 refrigerator manual
Not staying cold
Kenmore bottom freezer refrigerator 795.79004.905. Refrigerator not cooling.
Not an easy refrigerator to diagnose but here is a link to a Service Manual=> HERE Go to pages 21 through 23 and try to do the diagnostics. The problem could be several things including a defrost failure. Otherwise you will need to get a technician out to help you resolve this. I will try to help you should you need ask.
Appliance 911
Oct 06, 2015 | Kenmore Refrigerators
Have a Kenmore side by side refrigerator freezer gets cold but refrigerator side stays at 40 degrees
The refrigerator of fresh food side is supposed to be around 40 so its working correctly.
Feb 27, 2015 | Kenmore Refrigerators
I have a kenmore coldspot side by side. the refrigerator part is not staying cold. there is condensation inside. the freezer seems to be running fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 27, 2011 | Kenmore Refrigerators
My freezer gets cold but fridge stays warm i have defrosted and the problem continues kenmore model# 9704284 any suggestions
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore Refrigerators
Refrigerator will not stay cold
Eeeh, this will prevent you to spend more than you have. Carefully unplug your fridge, remove it from the wall for about 1 foot wait 15 mins and plug back and let it stay there for ever.
Sep 16, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
The top shelve of kenmore refrigerator stay too cold
I think my problem seems better now that I"ve lowered the temp to almost off. Oh by the way, what made you think I have a side by side. What I do have ias a 10 year old single door kenmore.
Jan 09, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
