Won't draw water
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
SOURCE: Saeco Aroma Espresso Machine.....doesn't draw water.
You have to take a bellow pump or similary and fill with water, after that you have to open the steam knob and put force in the water from the bellow pump into the water inlet on the machine.
Hope this will help you, let me know if it works.
/Mirran
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
SOURCE: I removed the water reservoir
Try unplugging the machine for about 5 minutes. And plug it back in. Let it reset.
SOURCE: Water won't pump through. I can hear pump. I
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
