Question about Coffee Makers & Espresso Machines
Thermaflow boiler problems - Coffee Makers & Espresso Machines
What is the power requirement for installing a Simpson 2001 66-647 thermaflow freestanding oven?
For Electric Range - 220 - 240 volt, 60 hertz, properly grounded circuit with 40 amp breaker or fuse protection with #8 gauge wire. With a 50 amp breaker, # 6 gauge wire is required.
The owner's manual below mentions the wattage. (download the document, hit CTRL-F on your keyboard, type in wattage.) You might contact the manufacturer or for that matter the electric company servicing you.
https://john.daltons.info/appliances/Simpson_2001_models_68-642_and_68-646.pdf
Jun 11, 2017 | Ovens
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Power boiler froze and then blew apart where the element enters the boiler. Hoping to remove boiler and get it welded. (not sure re-garding removal)
There are 2 boilers on these machines, Which one are you having this problem with?
I might have the tank/boiler for the group heads.
If you remove the boiler, Replace O'rings and gaskets.
Dec 21, 2010 | La Marzocco Linea Series Group 3 Espresso...
Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
May 26, 2010 | Ovens
Can't find circuit breakers on the boiler for Saeco Incanto
Hi
It depends on which boiler you have. If you have the round boiler (looking from the front top down, they will be on your left side). They will be on the bottom left side of the boiler. There are 2 of them on the round boiler and there are 2 wires to each thermostat. The button is between the 2 wires on the thermostat. You need to push both buttons. If you have the square flat boiler there is no reset button but a thermal fuse on the back side of the boiler. You have to remove the steam boiler ( horseshoe) to work on the flat boiler. FUN
Jun 17, 2009 | Saeco Incanto Classic Espresso Machine
Removal of hot plate hob
usually you have to take the side panels off and hobtop is secured by screws to frame
Sep 24, 2008 | Ovens
Simpson harmony nova oven , oven is heating up but fan wont work and oven does not heat enough to use.
I had same problem. Replaced fan motor,really easy,but still would not turn. Got my brother inlaw to check it. Turns out it was the thermostat. He gave the connections a cleanup with sand paper, like you do car spark plugs. Works great,
Apr 28, 2008 | Kitchen Ranges
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
