Question about Digi Sansonic FT-300A tal To Analog TV Converter Box
Need code Video is OK but there is no audio
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Feb 16, 2014 | Yamaha RXV371
Need remote control codes
Hello
For which device you need setup codes? You haven't specified anything detailed. Give me the Brand Names and Model Numbers of both your remote control and device to which you wants to setup codes with, by Fixya. Without these, how can one post a solution to your porblem/ Send me these details and help me to help you. OK.
Sep 10, 2011 | Audio Players & Recorders
Need code for my sky box for my digitrex tv to work from remote
Hello
Digitrex TV is not listed with Sky remote codes. OK.
Jul 05, 2011 | Audio Players & Recorders
I need the universal remote code for magnavox mdv3000 in order to program my at&t uverse remote
Hello
There is no codes listed for DVD/CD combo with AT&T Uverse remote code list. OK
Jun 28, 2011 | Audio Players & Recorders
I would like to know how to conect a Sony VHS to a TV? What leads go where etc. Thank you for your help.
hi,
you can connect the audio video out of your VHS to the audio video input of your tv. for that you need an audio video cable (have three RCA pin at the both side, one for video(yellow) and the other two (red and white) for audio.
connect the one end of the three rca cable to the VHS's audio video out according to the color code. and the other end to the tv's audio video input.
Then select the corresponding AV input in your tv using the remote.
ok
Jan 25, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Hi, i need to connect my tv with the dvd player...can't find the codes for either...please help
hi,
if ur tv and dvd player has hdmi connectivity, then purchase a hdmi cable and install it. if not it both will have component video connection. for that u need component video cable and one stereo rca cord for connecting video an audio respectively. bought it and install it.
ok
Dec 15, 2010 | Televison & Video
Need codes to add components to master control, I would like to add my cd player to master remote contol, reason cd unit has no remote
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 06, 2010 | Sony STR-DG510 Receiver
Bypass code for dual xdvdn9131? is there a bypass code for this new unit?
dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
Feb 18, 2010 | Jensen VM9510 Car DVD Player
Need insignia remote codes for comcast grey with red ''ok'' . for receiver
Most universal remote controls have a scan feature to find a code where one is not available. If this process doesn't work, additional assistance may be found at Community.InsigniaProducts.com.
Jan 23, 2010 | Insignia 200W Stereo Receiver
How do i Connect RCA VCR to Dynex 20" 480i tv
Ok yellow is always the video signel! and if you have a stereo vcr there should be yellow/red/white the red/ white are audio left and right! if your vcr is in mono then there will only be a yellow/white just use them and let the other red one hang free because it is not needed...if there are other color codes on your model just remember yellow is always the video(picture) the other are for sound and it does not matter where you plug them in at! If you have a black wire just use it in any audio input (red/white)
I hpoes this helps! if you need more help come see us
please rate answer!
Jan 24, 2009 | Dynex 20" Digital TV
Digi Sansonic FT-300A tal To Analog TV Converter Box Logo
15 people viewed this question
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
