Question about Frigidaire FFEF3013LW 30" Freestanding Electric Range
Hi,We have frigidaire FFEF 3013 LW. The oven don't go on.Bake or broil elements don't go on. I've checked probe sonde 1080 ohms and the elements 20 ohms each. I don't get any fault code.What do I have to check?
5 Suggested Answers
  • 184 Answers
SOURCE: Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Posted on Apr 04, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
2coolrick
  • 560 Answers
SOURCE: Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Posted on Jul 30, 2009
  • 206 Answers
SOURCE: bake or broil elements won't work.
Have you checked the main breaker or fuse for the stove? (lucky you did not get shocked.)
Do you have power to the stove elements?
If you have power to the stove elements, then I would look for a burned out wire in the path from the controls to the element. First place to start would be at the actual connection to the elements.
And glad to see you are still with us to ask this question. (((SMILE)))
Posted on Aug 18, 2009
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
My frigidaire electric wall oven feb27s5asb dies noto beat above 320
IF you have checked that the Temp sensor reads 1080-1100 ohms at room temp and your broil and bake element are 17-35 ohms, then it is the electronic oven control. please turn off power before troubleshooting.
Sep 19, 2016 | Frigidaire Ovens
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
What should an oven temp sensor's ohm reading be if it's at room temperature and not faulty? Whirlpool 30" electric range, model number WFE361LVD Bake element and broil element do not heat...
The oven sensor should be between 1000-1200 ohm's at room temperature or roughly 1080 ohm's. I would place the Tech Sheet here but Whirlpool will not allow me to post their manuals or Tech Sheets. You are welcome to the Tech Sheet HERE I hope this helps Thanks, Sea Breeze
Oct 22, 2011 | Ovens
Cant get the fan oven to heat up is this a element problem or a program problem.
Hi.
If the fan assisted cooking programs are the only one not working and the oven is otherwise heating and cooking, then problems can be:
Fan motor.
Wiring harness to fan.
The relay that activates the fan. That is usually part of control module.
If instead the fan oven is not heating at all, then check if problem is with broiling, baking, or with both. If the problem affects both broiling or baking replace the temperature probe. before replacement the probe can be tested using an Ohm meter. The probe will read about 1080 Ohms at room if good.
If problem is only with one of baking/broiling functions, then test elements or valve/ignitors, depending if oven is gas or electric.
Regards.
Ginko
Sep 18, 2011 | Electrolux Ovens
We have a ceramic top electric Frigidaire model GLEF378CCS. Neither the broil or bake elements work in the oven. Stovetop elements are fine.
check all wiring connections, if ok ohm out oven thermostat, if thermostat ok, ohm out oven elements and if ok, check voltage at oven elements. isolate problem.
Jan 25, 2011 | Kitchen Ranges
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Frigidaire FFEF3013LW 30" Freestanding Electric Range Logo
59 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
