Comfort maker model #FBA036GC1 ,3 toncentral air conditioner.what kind of capacitor do i need to replace?
SOURCE: Problem with capacitor of air conditioner?
the ratings of the capacitor should be on the capacitor itself in mfu sounds to me like the compressor stuck and cycling on overload is the capacitor distorted or swollen
Posted on Dec 29, 2007
SOURCE: fan not blowing
you need a 6.3v capacitor to get the fan going i had the same problem.
Posted on May 08, 2009
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
  • 32 Answers
SOURCE: I need to replace the starter capacitor for a 5
should be on the capacitor go to grange and they can match it up
Posted on Aug 29, 2010
  • 4736 Answers
SOURCE: how do I reset my energy star air
Turn the ON/OFF switch to OFF and unplug the unit for 15 minutes. Then plug the uni back in and turn it ON. During that 15 minute timeout, the unit should have reset itself and reverted back to the original factory settings. If it did, you can set the controls as you desire.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 25, 2011
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Carrier air conditioner model 38yca030370, need to know what kind of capacitor it needs?
Have him bring the old one back as it is yours. Check for the megaferons it has and the capacitance rating. Problem is hooking up thie wires needs to be done with knowledge of the system. $60 for a capacitor, $1200 for a blown compressor if hooked up wrong. You decide
Apr 20, 2013 | Carrier 38CKC042 Air Conditioner
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
Compressor fan moter not working
It is likely the capacitor for the fan motor. Unless you are comfortable working with 240v this is an issue for a qualified service tech. If you are comfortable with it, replacing the capacitor is fairly simple, you can probably obtain one from most electrical supply houses. It would be the smaller of the two capacitors contained within the exterior unit, the larger one is for the compressor motor.
Jul 04, 2009 | Carrier 36KCARMS Air Conditioner
Need a manual
looking 4 manual 4 comfort aire a.c. model#pe-121a serial# 070301060
Dec 29, 2008 | Comfort-Aire PAC-121 Air Conditioner
Fan not blowing
is it the condenser fan or inside blower???
Apr 26, 2008 | Weather King 10AJA2501AH Air Conditioner
Fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
