Question about Samsung Napster YP-910 MP3 Player
Nepster yp-910gs if connect the device via usb it shut down and say battery low, now it worse because it can't be recognise by usb port it say you usb this device has multifunction install the device drivers but still coming up
  • hamisi Apr 29, 2008
    connected player to charger for my blackberry cell phone. Now screen is blank. I don't know if battery is completely dead now or if something has happen to the player
The drivers are emebedded on the Napster version 1.0 download (installation disc) go to their site and select the download center, don't enter the model number, search by category instead. It will allow you download the Napster Ver. 1.0 and the recovery utility in case you need it.
Posted on Jan 24, 2008
Won't print...say's the printer is not-connected.
Try a new USB cable and switching the cable to a different USB port on the laptop. Check if a known working device will work on the laptop. Make sure that you aren't getting a low power situation (low battery, battery not charging properly). If the power adapter is unplugged, see what happens when the computer is attached to the adapter and getting power from the socket.
USB ports can be shut down for power savings so double check that your computer isn't doing this. (This is an advanced portion of the power savings settings and can be found via the Screen Saver Panel in Windows.)
Check the computer's hardware (Windows Device Manager) to check that the USB ports haven't been disabled by a driver problem or any other issue. Control Panel, Device Manager and scroll down to the USB device controller (Windows)
(the most common problem is the USB cable causing an issue.)
Apr 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Computer wont recognise my software for yp-u3 mp3 player
go to my computer icon on desktop !
click right mouse go to proberties --- system or device ---device management --- there you can solve the problem .
rate please !
best regards .
Jan 12, 2010 | Samsung YP-U3 MP3 Player
Cannot be recognised on my USB ports
The CD supplied does not have drivers on it. This is a flash player so your PC should recognise it automaticaly.
If this is not happening, please try installing an MTP Porting Kit via the microsoft.com website.
Jul 14, 2009 | Samsung YP-S3JAB Digital Media Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
My mp3 YP-U1 is cannot read in my computer pls. help me :(
Device is charging once connected to USB-port.
Is recognised by the computer but cannot be accessed.
Sep 09, 2008 | Samsung YP-U1 MP3 Player
USB connection problem
my YP-U3 player will not connect via my USB port. When plugged in to a port that connects my digital camera normally it first says on screen "USB Connecting" then changes after 2 to 3 seconds to "disconnected - Charging". it has fully charged and no change. I have checked the hold switch is disengaged. the media studio software is installed ok and the portable devices functions are greyed out. I cannot find the device on my pc. I am running Windows XP SP2. I will be returning it to the store where it was purchased very soon if i cannot find a solution. I notice there are a lot of people who have posted similar problems that have not recieved solutions.ya i have th same problem im using window xp 2
Aug 30, 2008 | Samsung YP-U3 MP3 Player
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
Samsung Napster YP-910 MP3 Player Logo
166 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
