Question about Tablets & eReaders
Toshiba at300se tablet disassembly any one know
How to diassembly my tablet
Don't know what brand/model you have so can't tell you.Try Google - disassemble (brand/model) tablet. Unless you are installing additional memory it is not adviseable to disassemble it if you have to ask how to do so.
May 14, 2016 | Tablets & eReaders
Blank Screen
The bad thing about this is that it could be a software related issue or a hardware issue. If you're willing, you can disassemble the unit and check for a damaged or loose connector to the monitor. If there doesn't appear to be any issues there it may well be that the screen has gone bad or there is something wrong with the driver/setting on the unit itself that is causing the screen to saty off. I'd move forward with the hardware issue first though.
Jun 09, 2007 | Toshiba Satellite R15-829 Tablet PC
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
Sound is not working on Toshiba AT7-C tablet. Anyone knows how to fix it.
Notification option may over ride in some tablets.
Do cold restart of the device to hear startup sound.
I would also consider verifying the latest firmware.
http://support.toshiba.com/support/viewContentDetail?contentId=4006098
Jan 31, 2015 | Toshiba Tablets & eReaders
How to unfreeze a toshiba at300 ?
Hold the power button down. Being that it is frozen may take a little longer than usual, but less than 30 seconds.
Sep 16, 2014 | Toshiba AT300SE-101 10.1" 16 GB Wi-Fi...
Broken LCD HInge
I do not know if this will answer your specific question, but there is s site that shows how to disassemble various Toshiba laptops. Here is the link. Select your model and follow instructions.
Mar 10, 2012 | Toshiba Portege M400-S5032 Tablet PC
How do i activate caps lock where is it??
How about to contact Toshiba for tech help?!
Because I don't know.
Android 4.0 Tablet PC
Feb 01, 2012 | Toshiba Thrive Android Tablet
I would like to know how to disassemble Compaq TC1100. Disassemble keyboard from screen unit.
There is a latch that you need to pull to seperate the keyboard base from the slate tablet pc. This latch is located behind the monitor where the keyboard attaches to the monitor.
Feb 26, 2011 | Compaq tc1100 Tablet PC
Loose ac power port
A very common laptop problem, but not always easy to rectify. Usually, the smallish receiver portion is fastened onto the mobo which means a total or near-total disassembly of the laptop. The part is rather inexpensive, but the labor to change it is not.
Feb 17, 2008 | Toshiba Satellite R15-S822 Tablet PC
Tablets & eReaders Logo
365 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
