Question about Coby MP305 MP3 Player
Manual lock sign and word hold comes up when I try to turn it on.
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
GB Pound Sign
If you have a desktop with a qwerty keyboard, try this
Press the Num Lock key (Num Lock light comes on )
Hold down the 'Alt' key and type 156 on the Numeric keypad ,release the Alt key and the pound sign should appear.
If that doesn't work,
Hold down the 'Alt' key and type 0163 on the Numeric keypad ,release the Alt key and the pound sign should appear.
Mar 31, 2015 | Computers & Internet
The key lock sign and a beep comes on and won't let anything else work?
Is child lock on? If it is you usually turn off by holding in the button so labeled about 3 seconds or so
Feb 25, 2015 | Washing Machines
My daughter tries to unlock my NTT docomo P-05D manyy times, the problem is, it locked permanently and it needs to unlock through signing in google. another problem is that my wifi is not turn on
make ready fingers for home and volume down keys (don't press now)
press power key , when vibrate almost end, both (home and volume down keys) press and hold also power key too...
than comes reset option
try many times, its timing on power on vibrate, be sure when almost end vibrate then press other bottoms and keep hold,
good luck
Apr 15, 2014 | Cell Phones
My phone wont turn on when i plug it up.
Holding the home and lock button at the same time reboots the phone. Press and hold the power button for about 2 seconds, the apple logo should come on then may go dark. Depending on how much data you have on your phone it could take a few minutes to boot up, just like your computer would.
Apr 14, 2014 | Apple iPhone 5
HI I DIDNOT CHARGE MY PHONE A FEW DAYS WHEN I TURNED IT ON IT SHOWED LOW BATTERY BUT I CHARGED IT IT IS STILL NOT SHOWING ANY THING NOT EVEN LOW CHARGE SIGN IT IS 3GS PHONE
try restating your iphone by holding both the lock button and the home key. hold the home key for 10 sec and then hold the lock button until you see the apple sign
Mar 01, 2011 | Apple iPhone 3G
My kenmore elite 106.59966803 beeps every two minutes. Doors are shut and the unit seems to be working fine. Any suggestions?
if the refrigerator is beeping -- then this is a sign that the door switch is not working properly,loose or broken.
to stop the beeping --- press and hold the "lock/alarm" button on the control panel until the indicator light turns off. ( this turns off the 'doors open' alarm ) --- now if you get the door switch fixed and you want to turn the 'door open' alarm back on, then press and hold the " lock/alarm " button again until the indicator light come back on.
c...
Feb 15, 2011 | Kenmore Refrigerators
I cant turn on my iphone, dark screen and stuck on the itunes sig
try to hold the home and power button and try 2 reboot it then wen u see the apple come on let both of them go
Feb 28, 2009 | Apple iPhone Smartphone
Unlock code to use
how can i unlock my ipod
Nov 26, 2007 | Apple iPod nano
Coby MP305  MP3 Player  Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
