Question about Watches
Remove links from fondini watch
How Do I take The Links Off To Size it down for my small wrist?
5 Suggested Answers
  • 29 Answers
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Posted on Mar 12, 2008
SOURCE: Invicta 2875 wrist watch band too large
http://www.geocities.com/watch_crazy/bands/bands.htm
Posted on Jun 30, 2008
SOURCE: Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Posted on Jul 14, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Need to take out a link or 2 to fit wrist. How do you remove the links
wrist watches links are made through two types of connection. First one is road based. the ends of the links are made in such a way that they make a round and interconnected with each other by sliding one link inside other then a thin road is placed in between the circle with spring loaded locking mechanism so that it shall not come out of the circle. In order to remove this type of link you are required to put the end of the link on a small hole and with the help of a small road tap the top of the road inside the links circle. Once the road is out you can slide out both the ends of the links and remove any number of links you wan't.
Second type of connection is made in half round type in this type one end of a link is made half circle and the other end is exactly same size hole the semi circle end fits inside the hole of next link. To remove the link you have to undo the semicircle part with the help of a plair and remove the link.
Dec 27, 2010 | Fossil Watches
I need new pins for my womens eco drive citizens watch to re size. where do i but them and what size do i need.
mcdevito75 here, besides the pins, you"ll need a special tool called a Pin Removal tool. By the time you order and recieve, it"s better to look for a small watch repair shop in your area for the removal / Install of these pins and links.
Aug 02, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
How do I reduce the size of a metal watch band to fit my wrist better
mcdevito75 here, You"d need a special tool called a link pin remover, BEST BET, look for a small watch repair shop in your area, hold onto the extra links once removed as you may need them again.
Jul 12, 2010 | Watches
Adjust band
mcdevito75 here, You"d need a tool called a Link reover to remove the links, available on ebay, however by the time you order the tool, recieve it, etc. The cost will be about the same if you look for a small watch repair shop in your area, have them remove the links. Hold onto these links in case ypou want them re--installed.
Jul 07, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Movado Juro watchband. How to shorten
mcdevito75 here, Best Bet, look for a small watch repair shop imn your area to svae on cost, special tool available on ebay is needed since it's a Movado let the shop remove links to re size.
Jun 23, 2010 | Movado Juro 0605024 Wrist Watch
How do i remove a link from the watch band?
hi friend,
step 1
Measure the watch band's length. Every wrist size is different, and there's no need to remove all of the links when you may only need to remove one or two. Putting the watch around your wrist and pinching each link around it to see how much room you need gives the jewelry wearer a reasonable estimate.
  • Step 258782_65x95_aspect.jpg Open the watch near the link you want to remove. Link watches have several openings, so even if you open the wrong clasp, it can always be reattached.
  • Step 358783_65x95_aspect.jpg Flick the tip of your fingernail inside the clasp to open the extra links. Continue doing so until you have removed all of the links that are too big for your wrist. If you have short fingernails, try using tweezers or anything with a sharp edge that can easily unfasten a link. New watches tend to be very stiff, so it may take a little nudging, but the links come off. It will be obvious which ones come off and which ones don't by looking at the back of the watch band. The links that come off have a claw on the tip of each one and sometimes have the brand name on top of it.
  • Step 458784_65x95_aspect.jpg Put the extra links in a safe place. There may come a time that you either let someone else borrow the watch or your wrist swells and you need these links again.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If you can't get the links to open, visit a jewelry repair store. Workers there may be willing to help you adjust your watch for free. If you bought the watch from a retail store, the jewelry counter is usually required to adjust your watch for no additional cost.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Kenneth Cole Reaction KC3367 Wrist Watch...
    Tessot steel wrist watch band
    i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
    Jan 13, 2008 | Watches
    Watches Logo
    47 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
