Question about Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH
Honda gcv160 what type of gas does it take?
SPARK PLUG GAP HONDA GC 190
When you buy spark pulg for most car or motor bic they are pery gap you do not need to do any thing .
Feb 25, 2017 | Gcv160 Gas Engine
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
Why does the honda engine surge
I have two pressure washers and honda engines on both. Carb needs to be cleaned I would bet,had to on both of mine. Good luck.
Jul 15, 2014 | Troy-Bilt 12avb29q711 Tb260 21-inch 160cc...
Small clear hose on Honda power washer
Sounds like the hose that goes into the detergent bottle.
Mar 21, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Poured oil in the gas tank by mistake of Honda water pressure model GCV160. Drained the gas tank, changed spark plug, drained carburetor still will not start
Sounds like you have oil in the gas galleries of the carb. Fill it with gas turn gas valve on and try starting it a few times with starting fluid to help rince/thin them out so gas can flow through them again. It may smoke more than usual for a while. Dont keep it running on the starting fluid though as it has no lubrication for the cylinder/rings and could scar the cylinder walls. If that doesnt work you can remove it and try to do it manually with a can of carb cleaner or get a new carb. They're on ebay for about $20 or a small engine supllier near you will have one for about the same or a little higher.
Dec 24, 2013 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Where is the carborator
Hello. The carburetor should be directly behind the air filter. I believe the unit you have is a GCV160 engine. Here is the link to the manual showing a diagram (see pg 9).
http://engines.honda.com/pdf/manuals/00X31Z8B0240.pdf
Should you have a different engine, here is the link showing how to identify it's type, then proceed to download that one instead.
http://engines.honda.com/parts-and-support/owners-manuals/gcv160
Hope this helped. If so, please rate this a four-thumbs up. Thank You.
Apr 02, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
NEED PART NUMBER FOR HONDA DRIVE BELT GVC 160
The drive belt will not be a Honda part but a Husqvarna part. 532408031 You can also get the same belt as an AYP part by dropping the "532" and using 408031. Hope this helps.
Feb 26, 2011 | Husqvarna 7021RH 21Inch 160cc Honda GCV160...
Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
