Question about Compaq Presario Computers & Internet
Toshiba c855 screen went black
Power on asked for reboot, put reboot disk in and shows loading windows files, than screen goes completely black with cursor still on, can move the cursor around. Help
    Filmmaker:
    Uploaded 5 video answers.
  • 30 Answers
Try to reinstall windows formatting your Hard Drive... It seems to be an windows crash, or some software.
Posted on May 14, 2014
  • 324 Answers
SOURCE: I have a Toshiba A105 Laptop, Screen goes blank after windows....
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Ron
Posted on Dec 15, 2008
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
  • 90 Answers
SOURCE: Black screen with flashing cursor
It may be because of your hard disk damage or OS problem. Try to install a fresh copy of XP from a cd. boot from XP cd and install .
Posted on Apr 06, 2009
  • 7 Answers
SOURCE: My Acer Aspire One shows black screen only.
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
parrotheadpc
  • 2600 Answers
SOURCE: black screen on toshiba satellite l35-s2174
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 14, 2009
Toshiba satellite c855-s5315 reset help please
This sounds like you have corrupt files in storage.
If you have made a boot disk or flashed a usb flash drive with the operating system, you may be able to recover your disk integrity.
If not and you cannot complete the steps below, contact TOSHIBA
Hope this helps
1. Type in the words "recovery media creator" anywhere on this screen. As you start typing the Windows 8 Search box will open.
2. As you type the name of the app you will see an app list show up onthe left
3. Click on the "recovery media creator" app
. Select [Yes] to allow the Toshiba App to make changes to this computer
5. Insert a DVD in your disc drive and select [Create]
6. You will prompted to insert a disc after each one is filled until the completion message below appears
7. Select [OK]
This completes you backup media recovery set!
H
Hope this helps
HH
Apr 14, 2014 | Toshiba Satellite L355D-S7813 Notebook
Screen goes blank after windows corporation logo
perhaps you need to reinstall the operating system,the system files might be corrupted because of power problem,and there's "windows loading files" thing,so the windows cannot go further because it cannot find some files while loading. do you need any help with installing operating system?
Aug 25, 2012 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite c855 screen just went black
have a toshiba c855, asked for reboot, put reboot disk in, show files loading than screen goes black with the cursor still working. Help
Jul 13, 2012 | Compaq Presario Computers & Internet
How to format Toshiba Satellite L655- S5098
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 18, 2012 | Computers & Internet
HELP!!! I was on my computer last night and all of a sudden the screen went black and I could hear sounds in the background, so I shut it down and when I started it back up, I can see the line where it...
Try to boot in safemode. Turn off the laptop and keep tapping F8 upon turning ON, the advance boot option will come out. Select the Safemode option just the regular one. Wait until loaded on safemode.
Try to back up your files under safemode. Your laptop is already infected with virus and the OS is starting to get corrupted. After backing up the files...you need to do the system recovery to completely delete the virus. The recovery instruction is on the disc case so follow steps. In case you don't know here's the instruction. Insert disc 1 and shutdown the laptop, hold C upon turning ON, let go of C when Toshiba screen comes out, always select the first option, like to select Toshiba recovery wizard. You don't really have to change anything because it's all set to defaults, all you need is to hit next all the time...when you see, "initializing the partition please wait" then that is the start.
Hope it works
Feb 26, 2011 | Toshiba Computers & Internet
The computer will power up, the windows loading screen comes up but after that the screen just goes black. you can tell the screen is on but completely black.
some operating system files have been demage, so, use your Windows CD to repair the operating system or installed a fresh copy
Sep 25, 2010 | Toshiba Satellite M55-S3512 Notebook
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
I HAVE A MICRON Trans Port TREK 2 model no. NBKU376. when i first got it it had windows 98 well ive installed xp on plenty other computers before, and have the factory os disk. so of coarse i wonted to...
look bro,
ur windows Xp is not installed properly..
Try to reinstall it i.e. from the boot via Cd stuff..
when u do so, like reformattin, u'll definitely be asked to format the partition in ntfs or fat32..
Select fat32 & then try to continue...
this should work..
if u liked my post & if it worked, please vote me i really need some good ratings thanks..
Nov 28, 2009 | Computers & Internet
Ran the Tshibery disk recovery disk. Completed and
Complete the recovery again but leave the discs in the computer. That way if the computer needs some files while rebooting it will take them off the cd....if not it will load and that will be the end of that. Just remember when you boot the computer for the first time to initiate the recovery, when it says to boot from cd touch any key...that is only done one time when you first initiate the recovery...after that do not touch any key if it says that...just let windows boot on it own. Once windows boots on its own, then you can take the recovery disc out and put it away.
Sep 07, 2009 | Toshiba Satellite A60 Notebook
Vertical Lines Display - Recovery shows setup not complete
As per my experience, the problem is not because of your Video Card/Driver. Such a problem arises due to faulty RAM. Change your RAM and enjoy computing.
Thanks
Sep 13, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
