Question about Avanti Refrigerators
TRYING TO FIND A THERMASTAT CONTROL FOR REFG
The mod # on it says 40RW/RC it is a old ice box, but works great still. However now it wants to just freeze all the time. Needs a new thermostat. But cant find 1 or the new number to look up for 1 thanks in advance
  • 1314 Answers
SOURCE: frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Posted on Dec 31, 2007
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
  • 84 Answers
SOURCE: Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Posted on Feb 06, 2009
bobicehouse
  • 1524 Answers
SOURCE: gegss20IEP does not get cold in top of freezer, food side warmer
Call him back. He needs to check the sealed system.
Posted on May 13, 2009
  • 351 Answers
SOURCE: Ice maker freexes ice together
maybe too much water going in to the ice maker
Posted on Jun 30, 2009
How can I change the MHz frequency
How to change frequency on RC toy car? - Instructables
www.instructables.com/.../How-to-change-frequency-on-RC...
InstructablesAug 4, 2009 - My friend and I bought 2 rc toys (1:18 scaled Ferrari F1) just for fun, but they work on same frequency (40.685 MHz) so we can't drive at same time. So i need some suggestions on how to change the frequency on one of them. The transmitter have quartz crystal, but receiver have only ...
Modding Fisher-Price 72825 Formel Junior Fernlenkflitzer
www.instructables.com/.../Modding-Fisher-Price-72825-For...
InstructablesI'll show you how to modify a rc toy car to work on a different frequency. ... the method I describe here should work with nearly every rc car. ... if you mean to change thefrequency from lets say 27.005Mhz to 27.415Mhz, it's basically the same.
How to change frequency on RC toys - Instructables
Dec 26, 2015 | Cars & Co Remote Radio Control Street...
Replaced working thermostat
Does the new thermostat have separate 'Rc' and 'Rh' terminals ?? If so, there probably needs to be a jumper wire across them to energize both the heating and the cooling circuits in the sub-base. Look carefully at the old stat and determine if it too had these terminals, if it only had an 'R' terminal, it was powering both circuits through that one single connection and probably had only one transformer.
The Rc and Rh terminals are for systems that have two separate control circuit power supplies, one in the A/C and the other in the gas (or electric) furnace.
Sep 17, 2015 | Heating & Cooling
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
Why does my ice maker is frezz up, and will not turn to make ice
I'm having a similar problem. Water freezes in the mold, but thermostat does not heat ice to release ice from mold. I replaced the thermostat and still did not work. I just noticed the plastic around the copper line that touches the mold prongs is melted. I guess it shorted out. You may have the same problem. Time to buy a new ice maker even thought the frig is only 1.5 years old.
Aug 16, 2014 | Whirlpool GI6FARXXy French Door...
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
RC-800M Remote Control
Are you trying to use the Insignia RC-800M to control a TV or some other JVC device? How old is the JVC product? Most universal remotes won't control a device that was built within 6 months of when the remote was programmed. (Newer devices will not work at all with an older remote.)
The RC-800M code for a JVC TV is 11601. For a JVC set-top box try the codes: 00775 or 01775. For a JVC DVD or Blu-ray player, try 32365. The manuals for most of the Insignia devices which came with the RC-800M remote are available from the Insignia support site: http://www.insigniaproducts.com/support.html .
I hope this helps.
Oct 01, 2013 | Insignia RC-800M Remote Control
Hi, I just bought a Honeywell RTH8580WF1007 and tried to install it, I placed the wires in on the same letters as they were with my old thermostat. However, now that the new thermostat is wired up, it wont...
739dfb58-7a38-4a51-a7ed-ab942a7253a0.pngRH is red heat and RC is red cool, red being the "hot leg" of the 24 volt control voltage, normally you will have a jumper from RH to RC, the fact there is an RC tells me there must be an RH too?
I will look after this post and come back if any new info was found, other wise I will say call 1800 Honeywell and provide you a diagram to check out.
Aug 25, 2013 | Honeywell RTH8580WF1007 7Day Touch...
Water drips from both ends of the ice maker ice maker. Ice maker does not appear to have a crack in. Could you tell me how to fix it? Is a GE model 3 PSC23SHMD BS
Most likely your water control valve=> WR57X10032 Water Control Valve RC This page has great instructions also. Many things can affect your ice maker so I will send this movie about ice maker related problems.
WR30X10093 Ice Maker Assembly
I will put it like this, if you can unplug the ice maker from rear wall of freezer and water continues to flow replace water valve. If only when ice maker is plugged in then the ice maker electronics and replacing the ice maker would be your best bet, Thanks, Sea Breeze
May 04, 2011 | GE Profile PSS26NGS Side by Side...
Ice maker is in off position. ice in hoper is melting and then freezing to everything below it. Air balance is set to almost 3 and thermostat is set to 3 1/2 witch make things in bottom of refrigerator...
its sounds that you may need to buy a new frige. trying to repair it part by part will have you spent more. well this is just me, i would rather not risk things if there are alternatives :) thats the lesson i learned from my p.c, its obsulette, old and **** and needs "renewing" my dad spent literally more than what is needed to buy a super great pc, from repairing this dinosaur.
Apr 21, 2011 | Refrigerators
Refrigerators Logo
53 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
