Question about Metabo Drills
Bypass Code metabo drills
Drill will not work without code
  • 14 Answers
SOURCE: drill
Hi hope to help
sounds like you have a problem with your brushes they may just need replacing but do not strip the drill down to do this just take out the batery then take the 4 screws from the rear off the drill and take off the cover see if the brushes are worn it doesnt take a lot of wear to be worn.
You can take off the wire from each brush unit then use a small flat screwdriver to pop out the brush unit then replace you should be able to get the brushes from any dewalt stockest.
Hope that helps. Sean
Posted on Mar 04, 2008
emissionwiz
  • 79847 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
  • 417 Answers
SOURCE: Drill hole in China Plate
Normally you would use a masonry bit to drill into ceramics eg tiles or bricks. if the plate is glazed it is better to stick some masking tape or adhesive backed paper on the area to be drilled to stop the drill bit slipping around. also i would be inclined to use a hand turned drill or a small battery powered drill if you have one to avoid breakage of the plate.
Posted on Oct 13, 2008
SOURCE: Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Posted on Apr 11, 2009
  • 398 Answers
SOURCE: when in drill mode the tork still kicks in on my dewalt
there is a gear and a clutch as agier said in the head. if its old it looses its catch, youll need to take it apart and look at it. the torque setting just tightens on the head the more you tighten it the less it will give( the ratcheting you hear when you set it low) .expensive drill so its worth trying to fix. how old is it? as for drilling thru knots and hard wood make sure your bits are sharp, you can spend alot of time trying to drill with a dull bit. do you sharpen your bits? i do alot of drilling with battery drill thruout the year and believe me a sharp bit is waaaay easier. though ive never had to sharpen concrete bit because they always break when they get old and i buy new.
so your saying it stops completley when you hit something hard, right. does it ratchet?
Posted on Apr 23, 2009
I have a 15.6v NiCad metabo drill can you replace 15.6v battery with the 18v which fits exactly the same in the drill
No the motor is only rated for the voltage that came with it it might work for a little bit but will burn it up
Jul 03, 2015 | Metabo Drills
Metabo uhe 28 multi code
http://www.metabo.com/International-Homepage-english-The-craftsman-s-brands-world.2786.0.html?&L=2786 You have no question but I do see the name metabo so hope this helps. It's the Metabo factory site where you can get parts breakdowns and more.
Jan 04, 2013 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Where can I buy a forward/reverse switch for a metabo right angle drill BE 622
Service Centers are listed on the Metabo Web Site. go to Metabo.US, then Services/Support, repairs and spare parts and in the center of the page click "Service Center". input your 5 digit zip code and it will offer you a list of all local groups that support the Metabo line.
Apr 05, 2012 | Metabo Drills
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
Mar 16, 2012 | Metabo SBE1010PlusC 1/2" 0 900/0 2,600 Rpm...
1/2" metabo hammer drill-
Did you check the carbon brushes?
May 17, 2011 | Metabo Drills
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
Feb 06, 2011 | Rotary Hammer Drill Metabo Uhe 28 Multi...
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Jun 03, 2010 | Metabo Drills
Metabo SBE750 hammer drill trigger sensitivity
The only possible sollution for this failure in this particular tool is to replace the switch. There are no additional electronics that could cause this.
Jan 14, 2010 | Metabo SBE560 1/2" 0 2,800 Rpm 4.5 Amp...
Hi, i hqave METABO 523 hammer drill that the
You're welcome to ship the unit to me for repair.
Contact me at info@taeckertindustries.com for more information
Nov 05, 2009 | Metabo Air Tools & Compressors
Drills Logo
53 people viewed this question
Top Metabo Drills Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Dennis Key
Dennis Key
Are you a Metabo Drill Expert? Answer questions, earn points and help others
