Question about Bunn GRX-B
Element My heat element (coffee warmer) died. Can I get a replacement part? PT # 38462.0001 Rev E
2 Suggested Answers
  • 35 Answers
SOURCE: I have a bunn coffee
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Posted on Sep 13, 2010
Had a power outage and now the warmer light doesnt come on and the water is cold. checked outlet and it is working.
This is most likely the thermal fuses on the heating elements. They are not difficult to replace but do a continuity check before the thermal fuse and the element terminal on each of the wires. You should be able get fuses from your local bunn distributor.
Mar 12, 2014 | Bunn NHB Coffee Maker
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
My 2 year old Bunn coffee maker was working last night but I went to make coffee this morning and the water was not hot, the switch on the side was off and the warmer wouldn't come on. I tried another...
Most probably the relay that drives both the heating element and the warmer.
A black thing like little box (relay)that containes 8-6 wires (2 from main board and rest just go other components.)
Thanks
Please rate my work
Sep 17, 2011 | Bunn NHB Coffee Maker
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
How come the water isn t hot anymore when i prepare my coffee
your heating element went bad in coffe maker replace heating element.
Feb 24, 2011 | Breville Die Cast 800ESXL Espresso Machine
Bottom heat plate is not hot enough
Warmer element may have dropped.Remove 3 screws and check.There are two nuts that fasten warmer to plate.
Jan 04, 2011 | Bunn VPR Coffee Maker
After cleaning, the brewer will not heat and the warmer will not light up or heat
Without the model number, it's only a guess but this failure is normally related to a protective device called a thermal fuse. If this has failed, the heater element may have to be replaced with it since they are often welded together as a unit.
Dec 01, 2010 | Bunn 10 Cup Home Coffee Brewer
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
Sep 13, 2010 | Bunn VPR Coffee Maker
Failed coffee maker
the "sensor" (little white hard material disc) works in conjuction with the heating element Ok thats a no brainer, however usually it is the heating element failure (lloks like a big U thing on bottom of hot plate) that kills the sensor. Both have to be replaced, however, are they easy to find and worth the cost of parts and time to repair?? Or just buy another one. The life expectancy is aproxiamate 500 or less pots...
Apr 20, 2009 | West Bend 55108 Espresso/coffee Maker
Coffee perks luke warm
Your heating element is toast! If you want to risk taking it apart, there is a fuse inside that can be replaced and if the fuse is still in working order, (test it using a meter), the heating element is dying.
There is nothing else to do, but buy a new coffee maker.
Feb 27, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Bunn GRX-B Logo
178 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
