Eurolux C85W bathroom heater
How do you install this heater
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
My eurolux dw2112p/1 gets stuck halfway in rince cycle
replace the timer: a tiny gear that is driven by the timer mpotor has broken teeth at that time point
Feb 04, 2013 | Washing Machines
I have a eurolux heater RW3324 that has no manual and it only turns on by the way its set. I have no idea how to un set it or set it or be able to turn it on and have it just be manual and heat immediatly
glennra, your heater is made by Omega. However, the model number you listed does not match any of their current heating appliance. You can contact their Customer Support Dept @ 02 9384 5678 and perhaps, they can email you an Owner's Manual as an attachment.
Hoe this helped you.
Jul 14, 2011 | Heating & Cooling
I purchased an aqua star 1600h-lp to be installed in a cottage. Question is, the cottage is heated with a large wood stove/fireplace. The water heater is located in a bathroom at the other end of the...
I would say that the wood fire/stove must have a heck of a draw to affect the bathroom heater. Maybe a separate air supply from outside via a pipe,to the stove meshed off against vermin would decrease the problem. Plus it could stop cold air being sucked across the room from an outside door.
Downdraft through the heater could happen with either vertical or horizontal vent. More important is the direction of the prevailing wind [horizontal] ingress of water/snow etc [vertical]
We often use the separate air supply in the UK and if the pipe bore is large enough 4" plus it seems to work ok.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Feb 14, 2010 | Fasco Heating & Cooling
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
I have installed a 4 gallon inline water heater close to the bathroom. The main hot water heater is at the other end of the house. Now the hot water in the bathroom runs luke warm when the washing machine;...
you don't have a circulating line in it,, there for it is pulling the hot only,, when you have the 2 systems you have to have it circulationg or take 1 out, it being it is hot water they will vapor lock,, meening no hot water , you could get a circulating pump that actually hooks to the cold and hot side under the sink far away from the water heater and it has a timer on it that will circulate the water at certain times of the day,,, this would solve your problem
Jul 02, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
New water heater, shower hot then only warm water in 5 minutes
try this, set the bottom therostat if it is electric , 10 degrees hoter than the top is set , if gas have no ideas
Dec 05, 2008 | Water Heaters
Horizontal electric hot water tank installtion
hello; no, unfortunately conventional elec. water heaters are only designed to operate in the upright position. one alternative is an electric tankless model. but beware there are a few things to explore about them before making the decision.
Mar 29, 2008 | Dayton Electric Heater
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
