Question about Garden
Fuji robin brushcutter parts - Garden
What is the Petrol/Oil mix for a Fuji Robin HT02
50:1 or if you want to use 40:1 , you can but may create muffler blockage after some time(on account of a lot of built up carbon, incomplete burnt oil) . Some use 40:1 if using regular 2 cycle oil and not synthetic 2 cycle oil.
Jun 20, 2016 | Garden
I need a muffler for a EY28D Robin Part No 234-30101-01. Is it available?
ROBIN SUBARU Engine Parts
Try exploring this link, there are lots of parts ... there is number given you can call them.
Jan 05, 2015 | Cars & Trucks
How do I replace the upper drive shaft on a Ryobi RBC430SEC brushcutter?
I couldn't find this model on google, but when replacing drive shafts in most brushcutters we used to slide the cutting head / gear assembly off the bottom of the shaft, remove the circlip holding the drive shaft if there was one, slide out the shaft from its square hole in the clutch at the motor end. If the shaft was broken we'd slide the motor part off the shaft to get the broken part of the shaft out.
Nov 10, 2014 | Garden
Re Fuji finepix, keep getting message turn off camera, turn on again as lens won't extend, so camera not useable, batteries fresh. any ideas? thanks, robin
Remove and reinsert the batteries or disconnect and reconnect the AC power adapter/DC coupler. If the problem persists, contact your FUJIFILM dealer.
Before that:
Carefully check if and eventualy where the lens is blocked. Don't touch the front lens. Feeling for any movement on the edge not on the glass. If there is not any obstruction, then perhaps the motor that should move the lens is defect. If you can find anything that blocks the lens, ask a technician if he / she can remove is. Or else I'm affraid you have to visit your FUJIFILM dealer.
Oct 31, 2013 | Fujifilm Finepix S2980
My Husqvarna 232R brushcutter pull cord will not start
There should be several 'dogs' exposed after removing the starter assembly. These 'dogs' should rotate into the flywheel nut when the cord is pulled causing the engine to turn. Check with a Husky servicing dealer for parts. Good luck!
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Trying to find a part
Parts Manual is available at http://www.robinamerica.com/media/manuals/128982825630877500.pdf
Though your exact model is not listed specifically, the same part number is used on both the 22 and 25cc engines across all listed versions. Worth a shot to call them up with part number and try to order it.
Oh, your part # is 524-60010-40, They can be contacted at http://www.robinamerica.com/contact.aspx and they even have an 800 number.
We can help you, just had to try. Hope it works out for you.
May 06, 2010 | Robin Subaru R1100 Portable Power 1100...
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
