Question about Brother MFC-3220C Plain Paper Inkjet Fax
Unit Waste Lots of Ink
Hi, I took my Brother MFC-3220c in for the upgraded computer replacement, Brothers had mailed me about. No cost. Now the fax machine cleans the heads every hour or so and wastes a lot of ink for nothing. I have had to stop using it and have it boxed up, sitting in my garage. I would LOVE to use it again. Can you help? *Oh, and can I set it, so it only does black and white faxes? Color costs too much and I usually need only black and white documents/copies anyway. Sincerely, Richard Amovernshaker(at)gmail
Since my original posting back in Aug07, I have two other ideas. 1. Only turn it on when you need to use it, and/or 2. replace all ink cartridges with black ink. Both ideas somewhat reduces it's functionability, but it may help a little.
Posted on Nov 15, 2007
I have had the same problem, so I decided to use the fax only for sending faces. I took the ink out of the machine so
SOURCE:
Over a month ago I called in and spoke to someone in customer service (technical). He isolated the problem to a new software change from Brothers that I needed to install. That person was to mail out that...
Many upgrades to software are available for download from the brother.com site.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc3220c_us
Any upgrades should be available at the above link that would show up on a cd that was promised.
However, I read on the following website that the upgrade is available on the 'Windows 7 Update' rather than the Brother DVD:
http://www.brother-usa.com/lp/windows7compatibility.aspx
Do you have Windows 7 running with this MFC 3220C copier printer?
Good luck on making your brother printer work for you.
Dec 15, 2010 | Brother Office Equipment & Supplies
I have an older machine: model MFC 9700. It has stopped receiving faxes and is showing an error message 71. Says to unplug and call Brother. Is this worth repairing? or smarter to invest in new...
Thats up to you. request a repair cost and compair it to the cost for a new one. Your choice mfc 9700 is a good unit. Upgrade to a MFC 4100n its one of the best brothers makes. Hope this helps.
Aug 12, 2010 | Brother Office Equipment & Supplies
I have a Change Unable 51 Error Message on my Brother MFC-260c MFC and it says to refer to User's Guide, how4ever there is no error code to match this in the guide. HELP!
hi karn..you need to disasemble your printer and clean your Maintenance unit....the coz of this error 51 is usually you are using competetor ink and then you have reset the counter (error 46) ,after you reset it, you need to change ink absorber if not it will bank those waste ink in the ink absorber and after it is full the waste ink have no place to store and it will jam the mantenance unit and the worse case it the ink maybe spoil other part of the printer go and find engineer  asap if not you need to replace new unit....
Mar 09, 2009 | Brother IntelliFax 1860C Plain Paper...
Print head for brother mfc-3220c
how do you remove the ink cartridge from mfc-3220c when the lever is stucki
May 18, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Fax receiving problems
Check whether there is any paper stuck inside.
Mar 24, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/[email protected]/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Cannot figure out how to set ring cadence(tone)
Turn on distinctive ring option as out lined in user manual.
Download manual from brother's web
Jan 10, 2008 | Brother MFC 3220C All-In-One InkJet...
Wastes Ink When Not Being Used.
1-did you try removing the chip?
2-the ink is not the problem, check the sponge on the bottom of the printhead in the home position.
Nov 16, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Color doesn't print before and after printhead replacment.
No, its not possible. The problem is likely the ink has dried in the purge unit or one of the small tubes going to the waste pad. The new printhead is the fix for the ERROR 41. The problem is there is sometimes other things that go bad, purge unit being just one example. One of the biggest problems with inkjets is that consumers leave their printers alone for long periods of time and the ink dries and clogs the tiny hoses inside. Even the ink cartdriges are just ink tanks, I have replaced those many times and have seen bad ones that just won't flow, replaced the inks and it works fine. You also have to put in the id# for the printhead after you replace it. Did you do that or get the instructions?
Sep 28, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C Plain Paper Inkjet Fax Logo
79 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
