Question about Danby DKC645BLS Compact Beverage Cooler
Danby kegerator o ring - Danby DKC645BLS Compact Beverage Cooler
SOURCE: new danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Posted on Feb 18, 2009
SOURCE: need a parts list for
I can obtain part breakdowns and replacement parts on danby appliances , Erin @ Jeffreys appliance service (509) 928-7176
Posted on Mar 17, 2009
SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Posted on Feb 15, 2010
SOURCE: Where do I get replacement parts for a Danby
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Posted on Mar 11, 2010
bobicehouse
  • 1524 Answers
SOURCE: Danby kegerator at 50 degrees.
How To Test the Compressor Relay Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor. Remove the compressor relay by pulling it straight off from the compressor.Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. bobicehouse_31.jpgThere are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Posted on Jul 14, 2011
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need... mark.pasieka@gmail.com
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
I have a danby kegerator that is spitting foam new keg settled for 3 hourd temp 38 3/16 line psi 9.5 help
Turn off the co2 for now. Turn it on when you need it, but start at a much lower pressure like 2-4 psi. Adjust pressure as needed.
Mar 22, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Jun 14, 2008 | Danby DKC645BLS Compact Beverage Cooler
New danby kegerator - tastes like rubber hose
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC645BLS Compact Beverage Cooler Logo
61 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
