Cabrio wtw7800 Lid frame breaks, glass pops out
4 Suggested Answers
richroth
  • 9472 Answers
SOURCE: glass separating from lid
You will need to replace the lid assembly. Here is the new lid to order.
Posted on Nov 21, 2012
  • 530 Answers
SOURCE: Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
Posted on May 12, 2010
  • 867 Answers
SOURCE: Whirlpool Cabrio Lid
The lock cannot be disabled, The lid removes easily and is also simple to replace.
Depending on where in the world you are depends on where you will get a lid, If you do a google search in your area for whirlpool spares you will get some results.
Posted on Mar 11, 2012
Cabrio wtw7800xl2 Lid frame beaks! Want TO Replace
You can try going to repair clinic at repairclinic.com and probably get the lid along with video help.
Aug 05, 2015 | Whirlpool Washing Machines
Has anyone had the glass top just popped off and is this a common problem?
Yes you would have to open the top cover and tilt it back to be able to get to the lid holder that breaks. Holders are at each end of lid. Labor will cost you if you call a repair company to replace those little weak holders. You may be able to do it your self. Good luck.
Dec 11, 2014 | Whirlpool WTW6400SW Cabrio Washer
How do I replace lid switch
Hello George;
My name is Peter. I am a retired field service appliance technician.
It would be easier if you sent me a model number. Generally the lid switch is white and has a plastic rectangular frame. The switch pops in. With a small screw driver, wedge under the switch frame and lift. There is a clip you can depress under the frame. If you are replacing the switch who cares if you break the clip. There are 2 contact wires on the clip (These are HOT). Disconnect the wires and reconnect them on the new switch. Be careful the wires do not fall in.
If this is not the type of switch that you have send me the model number.
Dec 11, 2014 | Washing Machines
I want to replace lid on my cabrio model wtw7800xw2 with a solid lid frame on glass lid keeps breaking
If all you want to do is to replace the lid, there are two TORX 15 screws on each side. Undo those and the lid should slide right off the pins. Be careful to not drop them into the tub or dispensers. You can then slide the new lid right on. Put the screws back on and test. If you lift the top cover off and mess with the springs, it is a PAIN to take off and put back on.
Feb 11, 2014 | Whirlpool Cabrio Washing Machines
How do I replace lid assembly for Whirlpool WTW8800YC 4.6 Cu. Ft. Cabrio Platinum Top Load Washer
Hi Sarah, there are two screws on each side of the lid holding the shaft for the hinges. Open the lid to access them, You will need an Allen wrench to take them off, after that, just lift the lid up to take it out. Hope this help. Thanks.
Feb 23, 2013 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Mar 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
How to fool the whirlpool cabrio 7340 lid switch? how can I look inside the machine while the machine is in operation??????? thanks.
PULL THE WHOLE TOP UP THERE ARE TWO CLIPS THAT HOLD IT TO THE FRAME IN FRONT YOU CAN POP IT UP WITH A FLAT HEAD SCREW DRIVER TO KEEY THE LID FROM CRASHING DOWN ON U TAPE THE LID TO THE FRAME IT SITS ON
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
can be a pain.
May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
