Question about Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43
What is the pston ring size
The piston rings in my Powermate PCV43 were broken and I am tring to find the ring size so I can order some new ones . Does anyone know the size and dimensions of these rings?
MIne too! I'm ordering some 43cc rings that seem to match the size of the one good one I had left. They are sold by many different eBay sellers and apparently are most all the same for a 43cc displacement piston....
43cc, OD=42mm, ID=38 mm, Thickness=1.5 mm
Posted on Apr 21, 2014
Motorcycle is losing compression and noisy
if it is a water cooled engine the ring gap at the bottom of the cylinder should be around .010"
rings have to be installed the correct way up or the compression doesn't help push the rings against the cylinder walls for effective seal
piston skirts will touch the cylinder walls as the pressure pushes the piston to one side as it pushes the piston back down the cylinder
I have to ask did you put an old piston back in the new cylinder
was the new cylinder standard size or over size
what was the ring gap before you fitted them to the piston
did you use new rings or the old ones --maximum rin gap is .025"
rings don't wear in , just wear out
why did you replace the cylinder in the first place
was it because of low compression or taper wear
as silly as all this seams it is all very relevant to your question
Mar 11, 2016 | 2011 kawasaki KLX 250
Why is my 250 recon knocking when has a fresh piston and rings with only 2 hours of riding it?
the question is did you remove the ridge at the top of the bore before you put the new piston and rings in. If you didn't then the knock could be from a broken top ring or broken ring land under top ring
all cylinders wear up to where the top ring stops and when new pistons and rings are fitted this wear point hits the ring as with a new piston the ring now travels further up the cylinder
May 13, 2015 | Motorcycles
Need a manual for powemate Pcv43
If you mean the Powermate PCV43, the Powermate Outdoors site has the manual on the product page: http://powermateoutdoor.com/soil_preparation/PCV43.html . The link to the manual is just below the model number. The direct link is powermateoutdoor.com/pdfs/om_cultivator_pcv43.pdf . Since the PCV43 tiller is sold at Home Depot, the product page there also has the manual: http://www.homedepot.com/p/Powermate-10-in-43-cc-2-Cycle-Gas-Cultivator-PCV43/202674371 . On this page, look on right hand side of the page as you scroll down to the Product Overview section.
I hope this helps. (Note: you will need Adobe Reader or a similar program to read or print the manual.)
Apr 24, 2015 | Garden
Just put in s new top end a yz 85 2008 , wouldnt start but could if it was bump started and ran bad. Opened her up again and there was marks all over the piston, help??
When fitting a new top end you may have broken the piston rings. On a Two Stroke engine the rings have a gap which must not enter any ports. To prevent this the slot for the rings has a metal peg to hold the ring gap in one place.
On Four Stroke engines there is no ring peg as there are no ports.
If a ring breaks whilst being fitted the broken parts will enter a port and then be dragged up and down the barrel causing damage to piston and barrel. The broken parts one having made their way to the top of the piston will be crushed between the cylinder head and the piston damaging both. The cyl head can be re used but the piston is most likely ruined.
Pete
Oct 03, 2013 | Motorcycles
Air is not building up pressure
There may be few causes for this.
1. The piston rings are worn out. If lot of oil comes in your receiver tank ththis is the indication to tell you that the piston rings and oil scraper needs to be changed.
2. The leaf springs strip is broken or worn out. If air is coming out of the suction filter open the compressor head with proper marking check and then fix back the same way you opened it.
3. One of the gasket is damaged or broken. Once again you will find air blowing out from the suction filter.
Aug 10, 2012 | Coleman Powermate 27 Gallon Air Compressor
Have oil in one of the spark plug cylinders what would be causing this ?
broken/worn piston ring(s). Each piston has 2 rings. These can be replaced by the DIY mechanic by
1) removing head of engine (remove head gasket - you'll replace it), then
2) manually wind the engine (with a ratchet wrench & socket) til the piston in question pops up
3) remove both rings (with ring pliers - available from any auto parts store)
4) install 2 new rings (with a ring installation collar - available at any auto parts store)
--- choose ring installation tool to the correct size for your pistons.
5) re-install head of engine (replacing head gasket)
Note that this procedure preserves the engine timing, so you need not reset it.
Dec 27, 2010 | 1997 Toyota Avalon
We need to order a new piston and rings kit for a 2001 yamaha blaster 200. Not sure how the measurements work. Tha calabrator is reading 66.35 on the piston and the jug reads 66.52. so we are not sure what...
take the measurement of your block.
having a smaller ring will ensure block not being damaged but prone to a Blow-By. a too-tight ring can get your block damaged. so for you to know which size to get regardless of the stock size, tyr to get the block measurement first, then off you go wich ring to get
Jul 12, 2009 | 2003 Yamaha YZ 250
Piston rings
First, be sure they actually do fit the bore. Take a ring and insert it in the bore. push the ring halfway into the bore using the piston. There should be about a 1/32" gap in the ring. Anything more than 1/16" and you need rings the next size up. If the ring won't go into the cylinder because the gap fully closes, the rings need to be a smaller size.
With the correct size rings, put them on the piston. Some pistons have an index pin in the ring groove Fit the gap to the pin. Put the piston mid-stroke and place the cylinder over the top of the piston. Squeeze the rings closed as you gently tap the cylinder downward and over the rings.
Please rate this solution. Thanks garethholleb!
Apr 04, 2009 | Gilera Runner VX 125 Motorcycles
Air leaks from top of nailer
Is this broken o ring about the size of the cylinder? If so that would probably be your air leak. You can go to Stanleybostitch.com and look at a breakdown and also order parts. If youu give me the model number I will help you with numbers. While you are at it how is the piston o ring, does the piston stay where you move it to or fall down without any pressure. If it does you might want to think about all new o rings for the tool. Let me know
Jan 15, 2009 | Stanley Bostitch N86S 1 Factory...
Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43 Logo
109 people viewed this question
Top Powermate Garden Experts
Dennis Key
Dennis Key
john h
Are you a Powermate Garden Expert? Answer questions, earn points and help others
