Question about Progress Lighting P868130 White Occupancy Sensor Wall Switch Occupancy Sen
Hubbell rms 141
Light not working
How to wire a Hubbell HBL26CM23 230V 16A shore power plug
Black wire goes to brass screw
White wire goes to screw with white finish
Green wire goes to ground.
Product Datasheet HBL26CM23
Sep 25, 2014 | Hubbell Boating
NEED REMOTE CONTROL FOR MODEL MC42-1012H M-1178 2-2007
I have the information on the wireless remote if you need it.
Aug 04, 2013 | Hubbell Electrical Products Hubbell...
Hubbell Special Products bed control
The only thing I can say is to either contact Hubbell Special Products, or contact Invacare and see what they say. I am looking for the same thing. Check all the **** on it and found out the remote is shot... Now have to work with them to get the right one now.
Aug 01, 2010 | Hubbell Electrical Products Hubbell...
Can I install a motion sensor switch on a 3-way switch?
In many cases, yes. When shopping for an occupancy sensing switch, read the label to make sure that it's compatible with 3-way switching, and then follow the installation instructions.
Feb 06, 2010 | Hubbell HBL1221I Industrial Series Switch
I need a postlight receptacle
http://www.touchandglow.com/Accessories-s/63.htm $15.97
Jun 23, 2009 | Hubbell Electrical Products 1 Gang...
"Double" electrical switch has failed to function
In a standard 3-way switch arrangement you can turn the light on or off from each position.  If the wall switch has failed then only the bed switch will turn the light on/off.  Replace the wall switch with a new 3-way switch.
Jun 02, 2009 | Hubbell Electrical Products 2 Gang PVC...
Progress Lighting P868130 White Occupancy Sensor Wall Switch Occupancy Sen Logo
104 people viewed this question
Top Progress Lighting Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Progress Lighting Electrical Supply Expert? Answer questions, earn points and help others
