Question about iBuyPower Computers & Internet
Apphangb1 fix The program GameClient.exe version 0.0.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel. Process ID: 6f84 Start Time: 01ce4d1cb7444901 Termination Time: 141 Application Path: C:\Users\Public\Games\Cryptic Studios\Neverwinter\Live\GameClient.exe Report Id: df0d8b2b-b915-11e2-8bf3-ef0ea78bf5dd
Mesmo
  • 164 Answers
SOURCE: windows explorer has stopped working
Well if it continues to crash then theres a bigger problem
but a way to make it recover if the EXPLORER.EXE crashes is to hit
CTRL+ALT+Del
File
New task
Then type Explorer.exe and it should reload itsself and be back to normal
i also suggest running a scan with Ad Aware 2008 just in case wat u downloaded could by spyware
Posted on Oct 21, 2008
Romy_Dec
  • 56 Answers
SOURCE: WINDOWS EXPLORER HAS STOP WORKING
Hey there
The problem could be because earlier version of nero You can solve your problem from doing the following:
If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
If you’ve upgraded Nero and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
This will break Nero Showtime, however.
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate or windows explorer) can fix this problem. This solution is detailed below.
Right click on Computer, and choose Properties
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe
Click Open, and then OK.
Enjoy working
Gimme your acknowledge by rating me
thanx
Romy
Posted on Oct 24, 2008
bunnydawg
  • 5158 Answers
SOURCE: I have downloaded avs video
run the compatability wizard and run it in xp mode... start menu... control panel.... programs.....under programs and features you will see "use and older program with this version of windows" run the wizard and locate your program... run it under xp and you should be good to go
Posted on Mar 20, 2009
SOURCE: I have the following error when I lunch google
you need to reinstall chrome because there is a corrupt or missing file needed to remain stable........click here to get it....when ur done make sure you remove all other internet browsers and set chrome as your default...you should be good to go. Good Luck and pls rate this post!! :D
Posted on Oct 08, 2009
SOURCE: Windows Vista Ultimate 64-bit & Warlords Battlecry 3
Sorry for my English.
BLUS, start game in a mode of compatibility with Windows XP
Posted on Nov 30, 2009
Utorrent is not responding.
have you tried to reinstall utorrent? if so, and it still doesn't work, you can remove utorrent and then run ccleaner which you can download from piriform.com after running it, try and do the installation again. if still no help i'd try a different torrent program such as vuze.
May 09, 2012 | Computers & Internet
Problem Event Name: AppHangB1
Check that your computer has the correct operating system for the game, and that the hardware is correct against the spec reqd. on the side of the box.
Mar 17, 2012 | 2K Games Sid Meier's Civilization V for...
A problem caused this program to stop interacting with Windows. Problem signature: Problem Event Name: AppHangB1 Application Name: plugin-container.exe Application Version: 7.0.1.4288 Application...
Seems more likely that there was a virus threat and attack that had caused the firefox browser to hang up. You can shut down and restart, try and use a good active antivirus to scan, check and repair if there was any damage on the OS .If not you can uninstall the forefox and reinstall.
Nov 08, 2011 | Mozilla Firefox
New computer with 64-bit...can't install my current version of Compton's Interactive Bible. Is there a fix available
Install it in compatibility mode as an administrator.
1. Right click on the program's shortcut, .exe file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. To Run a Program in Compatibility Mode -
NOTE: Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.A) Check the Run this program in compatibility mode for box. (see screenshot below)
B) Click on the drop down menu arrow and select which version of Windows the program was made for. (see screenshot below)
NOTE: Always pick the latest Windows version the program was written for to have a better chance of it running properly in Windows 7.Check run as administrator.
Aug 31, 2010 | The Learning Company Compton's Interactive...
Keep getting this error - agpr.exe has stopped working Problem signature: Problem Event Name: APPCRASH Application Name: agpr.exe Application Version: 0.0.0.0 Application...
This little critter is the problem
"agpr.exe"
If its a paid for program you can connect the supplier for help and advice about re-registering the program.If its a free program I recommend an uninstall using a free uninstall tool (Revo) and a re-installation
Close all other programs while uninstalling, downloading and uploading
Download Revo - double click on the Mindscape program - Then select the 'Advanced' mode - Revo will make a Restore Point and then uninstall using the Mindscape uninstall software.
It will then scan your C drive and Registry for all fragments and files that failed to uninstall.
Delete everything it finds
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Analyze' control to find the files and 'Run Cleaner' control until 0 bytes are seen to require cleaning
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
http://www.filehippo.com/download_ccleaner/
Re-start your computer
Reload your program
Download Yahoo Messenger from here.
Aug 27, 2010 | Mindscape American Greetings Print...
Arcsoft VideoImpression
This is windows Vista? What have you changed since it started crashing? The most common cause of crashing programs like this are the result of a graphics driver.
Mar 07, 2017 | Arcsoft VideoImpression 2 for PC
Feb 09, 2009 | Enlight Interactive Warlords BattleCry 3...
Application crash
hello,
i was trying to login on My BDO Internet Banking and the website is crashing everytime i open it...
here is the application error...
Problem signature:
Application Name: iexplore.exe
Application Version: 7.0.6001.18000
Application Timestamp: 47918f11
Fault Module Name: StackHash_fd00
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 03590cc6
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
can anyone help me please....i appreciate it!!!
Oct 23, 2008 | Yahoo Messenger
Computers & Internet Logo
173 people viewed this question
Top iBuyPower Computers & Internet Experts
NOEL
NOEL
Yagon
Level 1 Expert
Robin Hill
Robin Hill
Are you an iBuyPower Computer and Internet Expert? Answer questions, earn points and help others
