Question about Sub-Zero MW24 Microwave Oven
No heat generated in microwave or convection oven mode
Everything else works fine: power, fan, timer countdown, turntable, but there is no heat being generated in either microwave or convection heating mode.
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
Sounds like you either have a door switch that's not being activated, or is defective. Check the secondary (usually lower) switch first.
Another possibility could be a defective thermal cutout on the oven cavity.
Posted on Jun 12, 2016
    New Friend:
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
Posted on May 24, 2014
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
I cannot stop the DEMO
Demo Mode The Demo Mode is ideal for learning how to use the microwave oven. When set, functions can be entered without actually turning on the magnetron. The microwave oven light will come on, the fan will run, the countdown will run very quickly in the display, and the turntable will rotate. To Turn On/Off: The microwave oven and Timer must be off. Touch and hold TIMER SET/OFF for 5 seconds until 1 tone sounds. Repeat to turn off.
Jan 21, 2012 | Whirlpool Microwave Ovens
Everything seems to work fine, timer, power selection etc., but does not heat food???
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 25, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Nov 24, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Microve turns on, but will not heat Model number is FMT148G1B2 Everything seems to work except there's no heat. Clock works, countdown timer, light, turntable, etc., just no heat.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 16, 2009 | Frigidaire FMT148G1 Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
G.E. Profile Spacemaker XL1400 will not heat food
This can be the magnetron power supply area, the controler for the magnetron power supply, or the main control board itself.
If the turntable is spinning, the countdown timer is working, and the fans are going, this leaves out the possiblity for a defective safety switch.
I suggest you send the microwave oven out for an estimate if it is out of warranty. I would not suggest you try to fix this yourself.
Jerry G.
May 25, 2008 | Microwave Ovens
Microwave Ovens Logo
265 people viewed this question
Top Sub-Zero Microwave Ovens Experts
William Miller
William Miller
Are you a Sub-Zero Microwave Oven Expert? Answer questions, earn points and help others
