Question about Sanyo PLC-XU78 PLC-XU78 XGA 3000 LUMENS PROJECTOR Projector
Wont power lamp cycles on and off - Sanyo PLC-XU78 PLC-XU78 XGA 3000 LUMENS PROJECTOR Projector
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Sharp LC 37HV4M Flashing red light on screen when attempt to switch on and the remote tuner box wont fire up even though the power is on?
hi,
your main board or powersupply is faulty
or
One problem involves the lamp cage being loose. The fix is easy. All you do is remove the lamp and put it back in, making sure everything is tight. I guess they had a problem at the factory, for a while, not tightening the lamp cage. After a certain number of heating cycles, the lamp quits making connection.
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
LP70 lamp will cycle on and off in 3 min. intervals.
go into the menu and check the lamp hours. if it's over 2000, you need to replace the lamp. if it isn't, the power supply and/or ballast is starting to fail.
Jul 06, 2009 | InFocus LP70+ Multimedia Projector
Replaced the lamp, still wont come on.
1- Did you make sure you have the lamp door on correctly, there's a safety switch that activates and wont let the lamp light for your protection.
2- Put your ear close to the lamp door and listen for a slight hum as soon as you turn it on, it will go in cycles. If you don't, it's going to be the ballast module or the color wheel, both these have to be working to let the lamp light. I suggest you call a service center after that, that's the best thing.
Feb 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Cycle wont start.
Scottie...your question has no answer since you've not said what kind of machine..whether you've checked power..is the timer mechanical or electronic. Check your power by using a lamp plugged into the same socket. If that doesn't do it...get technical help.
Mar 30, 2008 | Washing Machines
Sanyo PLC-XU78 PLC-XU78 XGA 3000 LUMENS PROJECTOR Projector Logo
13 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
