Question about Garden
Huskee 13wj771s031 when i try to engage blades it the v-belt keep slipping under the idler pully
  • 79 Answers
SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
Posted on Apr 07, 2009
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 81 Answers
SOURCE: Mower wants to stall when blades are engaged
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Posted on Jun 23, 2009
  • 1111 Answers
SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Posted on Aug 07, 2009
  • 3911 Answers
SOURCE: I have a troy bilt pony and the drive belt to
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Posted on Apr 06, 2011
What would make the serpentine belt keep slipping off
Failed Water Pump
Crankshaft Damper Worn
Failed Belt Tensioner
Failed bearings in any accy
Aug 16, 2014 | Cars & Trucks
The blades on my John Deere GT 235 will engage but when lowered to cut the grass they stop. Any suggestions will be helpful.
you may have a bad belt. when engaged it could be slipping or the belt has jump off of idler which keeps the belt tight on the rest of the pulleys
Jun 30, 2014 | Garden
I have a Huskee riding mower- 18.5 hp with 46 inch cut. The mower has 3 blades. When I engage the blades the belt squeals but will go ahead and cut until it gets hot at which time it will stop pulling. The...
check the pullie blade bearing if it is going out it would make the belt squeak and when it gets hot it will make the motor lug down I have worked on mowers for 41 yrs.
Aug 14, 2011 | Garden
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Loose belt
No, you have an idler pulley which keep tension on the belt. You may have a problem with the idler pully or the belt may be worn or the drive pully slipping.
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Serpentine belt slips off idler pulley
The A/C pully is supposed to spin freely until the AC is activated to run.. The cranshaft pully does not. Replace the tensioner pully. The belt has to fit in between the grooves on the pullys.
Apr 05, 2009 | 1994 GMC Suburban
Not sure how to replace the belt in my MTD, Wards snowblower
Remove the housing with the machine off
The idler pulley is designed to push up against the outside of the belt between the drive and motor pulleys when disegaged the belt should look like a loop like a race track
engage the blade clutch and watch to see if it presses up against the drive pully and the motor pulley
their should be a spring attached to the idler arm and i believe the new belt is dragging a little
you should be able to move the belt with your hands ( it should slip freely) rod is engaged or it pulls the idler away
Either a spring causes tension when the rod is engaged or it pulls the idler away
Keep working with it until it is free you may have an adjustment on the spring tension or the linkage rod has an adjustment
I am sure you can do this without an diagram good luck
Nov 18, 2008 | Sport & Outdoor - Others
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
