Question about Garden
Tecumseh 3.5 hp pressure washer engine model h35 engine family 4569ix is leaking water on bottom? What do i do?
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
dniro592006
  • 121 Answers
SOURCE: Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Posted on Jun 11, 2009
  • 3600 Answers
SOURCE: pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Posted on Jun 22, 2009
  • 3600 Answers
SOURCE: Changing oil on a Tecumseh 3.5 HP engine used for
30 weight detergent oil.
Posted on Jun 26, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
Rigid 3300psi Pressure Washer chokes after engine warms up. Then looses water pressure. What is the problem and can I fix it?
if the engine slows then so will the pump... and so will the pump power.
engines are all the same and so just google "servicing engines"
an engine requires fuel - air - ignition and compression......
if your engine starts and runs then it must have reasonable compression so check / replace / clean the fuel and air filters...
check the condition of the spark plug / clean it / replace it
after these basic checks you move onto measuring the compression and checking the carburettor which requires a level of skill you may not have
oh, check the oil too !
if you have a make and model of engine (not pressure washer) the manufacturer may have service kits and service manuals... briggs and stratton / honda / tecumseh (you'll be lucky) / sumec linhai
Aug 30, 2013 | Legacy Extension,angled Rigid - LEGACY
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Jul 03, 2010 | Tecumseh Enduro Vertical Engine 16 HP 1in...
I have an old mini bike that I need to repair for my son, I have the frame all ready, I have a Tecumseh engine that came with it, I don't know what model it is, Maybe a h30 h35 not sure, no ser.# any place...
Tecumseh has gone out of business. There is a parts supplier who bought up the parts inventory but my last order of a carb took four months to get shipped. Honestly, your best bet is to get a Briggs and Stratton engine then alter the frame mounts to fit the engine. The project will go quickly and you can get parts when needed.
May 18, 2010 | Motorcycles
Need free repair manual down load on Troy Bilt Junior 500 30 82
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Free manuals for Troybilt here
May 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy bilt pressure washer
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
Mar 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Leaking carburetor
replace to gaskets on the bowl and usually theres a screw/or spring release on the bottom of the bowl....replace those gaskets as well
Feb 27, 2009 | Karcher 2500 PSI Pressure Washer
Unable to start gas engine on a NorthStar pressure washer
Disassemble and clean the carb. If it ran briefly with the starer fluid then gasoline is not coming through the carb.
Dec 30, 2008 | Northstar Garden
Garden Logo
277 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
