Question about meloncake My docomo checker
Arrows f-07d hard reset
How to hard reset Samsung 55UES7000
default is 0000
To perform a Factory Reset, follow these steps:
  1. With the TV powered on press the MENU button.
    1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Support section of the Main Menu, and then press ENTER.
      1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Self Diagnosis option, and then press ENTER.
        1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Reset option, and then press ENTER.
          1. Your TV will require you to enter your security PIN. If you have not set up a PIN the default is 0000.
            1. A factory reset warning will appear, you can cancel the reset at this time by selecting No.
              1. The TV will power off and when it is powered back on the Setup screen will appear.
Nov 02, 2014 | Televison & Video
Tip
HOW TO PERFORM A HARD RESET ON Treo 650
Performing a hard reset on a Treo 650will erase everything on the smartphone. Most people do this because of trouble with the Treo 650's software. There are several key stages to performing a hard reset. Follow these steps to learn how to do it properly.
  1. HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
  2. Step 2 Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
  3. Step 3 Let go of the red phone button when you see the Palm screen.
  4. Step 4 Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
  5. Step 5 Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
  6. Step 6 HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
on Sep 17, 2009 | Palm Treo 650 Handheld
Why does right-side deck ...no take-up on play?
The drive to the reel table has stopped. This can be a belt but in many cases it is a tire on an Idler wheel that need to be changed
May 07, 2014 | Pioneer CT-07D Single Dual Cassette Deck
Hard reset for a fuji finepix jz500
1.Press the "Menu/OK" button on the back of the camera.
2.Highlight "Set" on the LCD display by tapping the "Right" arrow button.
3.Select "Set-Up" using the "Down" arrow button. Press "Menu/OK."
4.Select option "5" by tapping the "Right" arrow button. Press the "Down" arrow button.
5.Select "Reset" by tapping the "Down" button. Press the "Right" arrow button. A confirmation message appears.
6.Press "Menu/OK." The camera resets itself to factory defaults
Sep 25, 2011 | Fuji FinePix A700 Digital Camera
My eXplorist 100 will not respond when the 'start' utton is pressed. Is there a 'hard reset' option somewhere on tjhis thing?
  • To perform a hard reset follow these steps
  1. Press "MENU."
  2. Use the arrow stick to highlight "Preferences."
  3. Press "Enter."
  4. Use the arrow joystick to highlight "Restart GPS.'
  5. Press "Enter."
Regards, Tony
Apr 28, 2011 | Magellan eXplorist 100 GPS Receiver
How to hard reset intermec CS40 series?
on the top of the keyboard 2 arrows after like this < and > near the button Scan.
So knowing that.
Put the battery off, re-plug the battery.
Push the 2 arrows at the same time and press start button (red phone) continuing to press the 2 arrows...
you have a screen that gives you choices
Clean boot (Option 2 is a hard reset), press 2
press 0 to continue.
Hoping that helps,
John PIGERET
Mobility Consultant - Technical Project manager junior.
Dec 16, 2010 | Intermec CN3
How to hard reset a 1312nfi
This reset will change user and network settings Before performing this reset it would be advisable to print some information pages to retain any settings that you might want to restore.
Configuration Page
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Configuration report, press OK.
Menu Structure
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Menu Structure, press OK.
Network Report
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Network Report, press OK.
After printing these reports it will be safe to perform an NVRAM initialization to hard reset the product. Follow these steps.
1. Turn the machine off.
2. Press and hold the right arrow and cancel (x button) while turning the machine on.
3. Release both buttons when Permanent storage init. is displayed.
Once finished resetting the machine will return to Ready.
Jun 16, 2010 | HP Laserjet CM 1312NFI Color Printer
I forgot my password on my palm treo cell phon
unfortunately, the password is made for protection from accidental or intentional access. The only way to bypass this would be to perform a hard reset and then hotsync your phone with your computer to put your contacts back on your phone.
For performing the hard reset that reformats your phone to factory condition, please follow the instructions below:
1. Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset
2. Let go of the red phone button when you see the Palm screen.
  1. 3. Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
    4. Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
    5. HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
Dec 26, 2009 | Palm Treo 650 Handheld
My palm treo is stuck on spanish and I have no idea how to change it back to english.
The only way to reset this to english is by performing a Hard Reset. It will remove all information on the phone BUT after it reformats it gives you the option to select English or Spanish.
The hard reset is performed by following the instructions below:
That should solve your problem! Hope this helps!
Dec 24, 2009 | Palm Treo 650 Handheld
Check map disc???
I have the discs you are looking for, i have the MDV-08D 2008 edition ver. 2.2 this will surly unlock your deck. no need to pay $200- $400, il sell you a copy for $75 bucks! You can contact me at RDAWG146@yahoo.com
Jan 19, 2009 | Eclipse AVN5500 Car DVD Player
meloncake My docomo checker Logo
475 people viewed this question
Top meloncake Apps Experts
Brett Duxbury
Brett Duxbury
Are you a meloncake App Expert? Answer questions, earn points and help others
