Question about LG 30" Over the Range Microwave Hood with Glide & Cook Tray, LMV1645S
Kenmore display says "locked" it will not work at all
Kenmore elite oven door shows door locked how to unlock it
https://www.hunker.com/12438447/how-to-unlock-a-locked-oven-door-on-a-kenmore-range
How to Unlock Locked Oven Door on Kenmore Range Hunker
Quoting from the link shown:
Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jun 15, 2018 | Kitchen Ranges
My Kenmore microwave says LOCK on the display. How do I unlock it?
  1. Touch and hold the "Enter/Start," "Start," "Lock" or "Control Lock" key, or key that has a padlock image, on your Kenmore microwave's control panel for about five seconds.
  2. Check that the word "Locked" has disappeared from the display.
More items...
How to Unlock a Kenmore Microwave ' Hunker
https://www.hunker.com/13408005/how-to-unlock-a-kenmore-microwave
Kenmore microwave says LOCK on the display How do unlock it Google Search
Mar 12, 2018 | Kenmore Microwave Ovens
Washer kenmore elite washer model 417.41102000 displays LOC and won't turn on. how to reset and unlock the controls?
Control Lock (Press & Hold) To lock the controls between or during cycles, press and hold the Add Steam button for 5 seconds. ' will be displayed if you attempt to wake up a "between cycle" locked unit and ' will alternate with cycle time remaining in a "during cycle" locked unit. Repeat to unlock the controls when you are ready to operate the washer. Use this feature to reduce the likelihood of accidental operation by children. 41741102000 KENMORE ELITE WASHER Manual Sears PartsDirect
Hope this helps?
Mar 29, 2016 | Kenmore Washing Machines
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Kenmore HE washer displays DL failure code-what can we do to trouble shoot before calling a home repair? This is actually a 45088 if that makes a difference
    A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
    Potential Causes
    • Door Lock Mechanism broken or removed from the Door
    • Check Door Lock/Switch Assembly
    • Check the wire harness connections to the Door Lock/Switch Assembly and
    Central Control Unit (CCU)
    • Door Lock/Switch Assembly Failure
    Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
    hope this helps....
    Oct 24, 2009 | Kenmore 45087 Front Load Washer
    Kenmore Microwave 62622 display says "locked" and will not operate
    hold your finger on the locked button till the light goes out
    Jul 04, 2008 | Kenmore 62622 Microwave Oven
    Kenmore elite microwave oven displays "Locked" and will not respond
    My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
    Mar 01, 2008 | Kenmore 62622 Microwave Oven
    Kenmore Elite Electric Range, Display stuck on LOC
    I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
    Feb 03, 2008 | Kitchen Ranges
    Kitchen Ranges Logo
    15 people viewed this question
    Top LG Kitchen Ranges Experts
    JP Services
    JP Services
    Oloyede Monsuru
    Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
