Question about Refrigerators
How to permanently remove ice maker - Refrigerators
2 Suggested Answers
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Posted on Jul 28, 2009
Why won't the ice maker shut off even when I shut off the switch? The ice maker does not use a shut off arm or lever
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Sep 05, 2014 | Kenmore Refrigerators
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
Ice maker won't shut off
Jan 26, 2014 | General Electric GSH25JFX Side by Side...
Ice maker ice dam
turn the ice maker off, take out the ice box and let all the ice melt try a knkfe in the ice maker to chip away whats clogged. it worked on mine but its not permanent. good luck
Aug 27, 2012 | Whirlpool Refrigerators
REPLACE ICE MAKER PART AP4345120
Remove the ice bin. Remove two screws, holding the ice maker and unplug the power cord. Remove the ice maker.
On the new ice maker install the water chute (plugs in) and install the new ice maker.
Mar 13, 2012 | Refrigerators
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Sep 20, 2011 | Amana AFF2534FE Bottom Freezer French...
On the Everstar HDIM35 ice maker does one have the option of a permanent drain line out of the ice bucket or do you have to drain it manually by removing the drain plug?
I have one. It is made for manual draining. The unit does have a drain on the back of the ice storage bin - you could perhaps modify the unit to install a permanent drain line.
Aug 17, 2010 | Kitchen Ranges
Water is leaking into my fridge section. I think its coming from the ice maker because there is also a layer of ice on the bottom of the freezer. how do i fix it?
Check if your drip tank is full or if the opening to the drip tank is blocked by some ice pieces or something similar. If yes, get it cleared. It may also happen with aging. If it is so, there is no permanent fix for this problem.
Apr 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
On my 106.55244400 refrigerator, does the cord to
If you remove the 3 screws holding the ice maker to the wall , and you do not see a plug at the rear , then unplug the refrig . Remove the ice maker cover ( it just snaps off ) . Where the line connects to on the ice maker , you will see a small square hole with a " flap " which has to be depressed , and the wiring will slide out , after unclipping the black fuse piece , from the mold .
Nov 13, 2009 | Kenmore 50522 / 50524 Side by Side...
Jul 06, 2009 | Frigidaire FRS23H7CS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
