Question about Drills
Ac-dc battery charger type:jDA-22ukc/60109010
4 Suggested Answers
jzonewarrior
  • 3 Answers
SOURCE: need pin connections to lg vx-4500 for DC charger
The phone side connection should look like this image
Posted on Nov 19, 2008
vortash
  • 431 Answers
SOURCE: I want to know what type of DC charger it uses.
Hi i am vortash just see how many batteries it uses .. each one will be 1.5 volts and add them up 2= 3volts etc then that is the voltage DC adapter you want then it just comes down to finding the right plug .They usually have a rubber cap over the dc input and it is usually a 1.5mm power plug ( looks like a tube with a hole in the center.) or sometimes a jack plug ..it should actually tell you in your manual if you do not have one you may be able to download one from this site free http://www.safemanuals.com hope this helps Regards Vortash
Posted on May 20, 2009
  • 33 Answers
SOURCE: Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Posted on Jan 27, 2010
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
My Kocaso M1062 will not take a charge and says connect charger.
The power Cell (Battery) no longer accepts a charge. The exception is if the AC/DC charging adapter has failed. See if you have a similar power charger around the house. Look for the same type of male pin and proper DC or AC Voltage plus Amps as listed on the current Tablet Charger. Never leave chargers in the electrical outlet alone as they can be damaged by surge power. Try another charger and if that fails also, the power cell in the tablet needs replacing.
Dec 19, 2013 | Kocaso Tablets & eReaders
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Can i use this lap top with plug in and not a battery?? where is the plug in?
I BELIEVE so. Some laptops require the Battery to at least be in the laptop, whether they are good, or not.
Others will allow the laptop to run off of the AC adapter (Charger), with the Battery not installed.
Gateway Support > Gateway MD26 series of Notebook PC's > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2364
Click on the - Support Documents - tab.
(Drivers / Applications / BIOS / Patches / Support Documents / etc)
Click on - Product Views - in the list.
Click on - Left View
Power connector
This is where the AC adapter (Charger) plugs in.
Examples, (Note US and Europe have different power plug ends),
http://www.batterytech.com/products.aspx?category=ac_adapter&brand=gateway&model=MD2614U&pid=AC-1990111
[The laptop uses DC electricity. Just like the Battery it has, and flashlight batteries. DC Voltage.
The AC adapter (Charger) converts your household, or business, electricity from AC to DC.
(19 Volts DC. In comparison two D cell flashlight batteries store 3 Volts DC ]
Regards,
joecoolvette
Oct 15, 2012 | Gateway MD2614u Notebook
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
Drills Logo
173 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
