Lg x140 display no bootable device insert boot device
Godshifter
  • 13 Answers
SOURCE: Media test failure, No bootable device, insert boot disk.
That happened to me when I tried to upgrade. If you don't have an external DVD drive, you have to copy the restore disk to a flash drive, put it in the USB drive, power up, hit F12 at the first screen, move the highlight to the USB and boot from it.  Oh, and it has to be at least    1 GIG, the USB Flash drive does, or it won't fit.
Posted on May 18, 2009
miksulder
  • 25 Answers
SOURCE: Telling me there is no bootable device and insert
try to go into bios settings and look for "reset to defaults" then save and exit, but do not chance everything else. If it doesn't work after that you have to run windows installation.
Posted on Jul 06, 2009
endisforever
  • 36 Answers
SOURCE: MY SYSTEM SAYS NO BOOTABLE DEVICE--INSERT BOOT
Okay, first things first. Unplug everything except for the power cord. Make sure the floppy drive (if you have one) and CD-ROM drive are empty. Go into your computer BIOS settings and make sure that the computer is set to boot from your hard drive first. (Depending on the computer, usually holding down F2, F4, F6, F8, or even other function buttons will allow you to do this. Not all of the buttons at once, but just hold each one down when you start the computer until the BIOS comes up). If this doesn't work, your Hard Drive is either corrupted, all information has been deleted, or simply came loose over time. You may be able to fix this yourself. The easiest solution is to reformat your computer using the original disks your computer came with. You can also use a licensed copy of Windows disk.
If you have information to recover, I would look into Bart's PE Builder (google it), although that requires another computer. If you have access to another computer there are many boot disks that you can download or buy.
If none of these work, try getting your computer into DOS mode. It's much harder with XP and Vista, but Windows ME and earlier it should be an option. simply type C:\ at the prompt, cd windows, dir/w. This will tell you if windows is still there. At least then you'll know your options. If windows is gone, the only way to get it back is to reinstall it. I hope something in here helps someone.
Posted on Jul 14, 2009
  • 742 Answers
SOURCE: NO BOOTABLE DEVICE INSERT BOOT DISK AND PRESS KEY
Do you have your windows OD running? If so, make sure that there is NO CD or DVD Disc left in your CD/DVD Combo drive while you are turning your computer ON. Now, eject the CD or DVD and try to start your computer again.
Posted on Nov 10, 2009
parrotheadpc
  • 2600 Answers
SOURCE: no bootable device message, says insert boot disk what is that
Usually this is idicative of a hard drive failure, try to boot with the windows cd and see if it will boot up. Try this below......
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 21, 2009
My question is that when I switch on my AsusX5DC it displays "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" Am lost. how do I reboot it?
Enter the bios. Set the first boot device to your bootable hdd or USB/DVD drives if you are reformatting and starting again with an OS.
Jun 07, 2016 | Computers & Internet
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
How do i fi no bootable devices on my Toshiba Satellite laptop
.- what kind of toshiba you have?
Normally, if you have a bootable USB stick (and your BIOS recognize this kind of device) insert it and give it a try.
Or, insert a bootable CD/DVD into your CD/DVD tray and boot.
Once the operating system was booted from any of those devices, proceed with installation of the operating system on your HDD. Good Luck!
Jul 20, 2014 | Computers & Internet
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
Mar 26, 2013 | Computers & Internet
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
I am inserting the bootable cd in lg combo but every cd run but bootable cd not run please tell me how can adjust the bios settings
first check the CD you are using is boot able in other system if not write a bootable CD and insert the other thing is of the drive if the drive is old and the lens are weak the boot able cd wont work you will have to find anew drive to test that remove all the ide connectors or sata connectors from the motherboard except the CD drive insert the boot able cd and and restart the system then press del and enter bios setup and click advanced option and make sure the first boot drive is CD then save and exit in some motherboard you need to use f12 to select the boot device then click it and select the boot drive as cd ROM then click click it then you will see after post bios boot from cd ROM press enter it will ask for confirmation press enter again you system then boot from the cd now switch off the computer connect the hard disk and try again
Oct 16, 2011 | Computers & Internet
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
Computers & Internet Logo
David Payne
David Payne
