Question about Xerox Solid Ink Printers 8570/DNM ColorQube Model 8570DN Color Solid
How to solve printer error 99,013 on xerox ColorQube 8570 DN
Printer shows printer error "99,013" Ink Melter disconnected
  • 208 Answers
SOURCE: Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Posted on Dec 07, 2007
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Posted on Jan 10, 2009
  • 49 Answers
SOURCE: Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Posted on Mar 31, 2009
  • 28 Answers
SOURCE: Xerox 8550 DN display does not work and printer does not print
This model of printer has a known fault with the LCD panel.
Contact xerox in your country, who will arrange to have a replacement front panel sent out to you to install
Posted on Aug 06, 2009
  • 17 Answers
SOURCE: Xerox Phaser 8500DN printer error : 09,037.45:67244
Please clear the ISC Fault (Ink Stick Count) from the Service diagnostic menu under function.
Posted on Aug 21, 2009
Xerox 8570 tray2 issue pickarm stuck
the problem of your machine is mechanical you must change your gears found on your machine.
Sep 06, 2016 | Xerox Corporation Xerox ColorQube 8570DT...
Printer Error: 93,984.00:34602 Xerox colorqube 8570
Check the crum for the cartridge. And does it fix proborly
Oct 22, 2015 | Xerox Office Equipment & Supplies
What is Xerox 8570 ColorQube error 93 984.00:3683
93,984 means: Cyan obstructed, reservoir not filled
• Check for ink spills around the Printhead.
• Check the Ink Loader for bent melt tips.
• Check the Ink Loader power cable misrouting around melt tips.
• Check height of ink levels in the head reservoir.
Mar 15, 2015 | Xerox Office Equipment & Supplies
What does error code 91,721,00:3959 on a xerox colorqube 8570 mean
That error is a printhead tilt fault. The printhead is not able to cam back and forth correctly. There is a kit that fixes that problem, part number 8570-Z1. http://www.iteminconline.com/itemdesc.asp?ic=8570-Z1&eq=&Tp=
Aug 26, 2014 | Xerox Phaser Office Equipment & Supplies
Reset maintenance kit on a xerox colorqube 8570?
There is no "reset", except to replace the Maintenance Kit. That will reset the life back to 100%
Apr 10, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Phaser 8570 makes grinding noise
Our Xerox 8580DN is making a grinding noise when starting up and then it doesn't start up it state that there's a jam.
Mar 12, 2013 | XEROX - COLOR PRINTERS COLORQUBE 8570/N...
Xerox 8570 error 93,984.00
A 93,984,00 error refers to an Ink Load Obstruction and Reservoir Not Filled issue and the machine needs to be powered off asap to avoid further damage to the printer. This relates to Cyan in particular. It is also worth checking all the other colours at the same time. You need to take the following steps:
1.DO NOT RESTART the printer as this could cause the head overfill.
2.Check for any ink spills around the Printheads and clean them up.
3.Check the Ink Loader for bent melt tips.
4.Check for the Ink Loader power cable being misrouted around the melt tips.
5.Check height of all ink levels in the head reservoir.
6.Restart the printer.
Feb 13, 2013 | Xerox ColorQube 8570DN Printer
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
Xerox Solid Ink Printers 8570/DNM ColorQube Model 8570DN Color Solid Logo
357 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
