Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Plastic Flywheel problem
I have a keystart mower. When I turn the key to start the mower, this plastic white flywheel uses its teeth to engage the motor to turn over. The problem is, the flywheel keeps lowering after it engages the engine. Then I turn the key again and the flywheel starts to turn again but it has lowered so low that it won't engage the part required to get the motor turning. There doesn't appear to be anything broken on the flywheel or the black rubber piece that the flywheel is threaded on. How do I keep the flywheel up so that it engages the motor? Thanks
  • 376 Answers
SOURCE: craftsman riding mower repair starter will spin but not engage
You need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Posted on May 29, 2009
  • 81 Answers
SOURCE: Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
Posted on Jun 20, 2009
RonInFla
  • 86 Answers
SOURCE: unstoppable hi idle
Carburetor flap is stuck open...must have been stored...take it to a shop...$40 or so...one day - done
Posted on Apr 17, 2010
  • 146 Answers
SOURCE: starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 15, 2010
rycgl
  • 1545 Answers
SOURCE: I have a Craftsman mower
There is the possibility that the valves need adjusting. As you probably know, if they are too far out of adjustment, starting will be difficult and there will be "runnability" issues. The Briggs OHV engines all have adjustable overhead valves. Just remove the little cover stamped OHV, careful with the thin gasket behind it and get a feeler gauge, possibly a Torx head driver and box wrench to do the job. Some of the set screws for the rocker arms have slotted heads maybe. The Briggs site has the instructions for this and ALL the specs on all their engines pertaining to valve clearance on intake and exhaust. Many of their OHV engines also incorporate a compression release feature which correct valve adjustment is critical for it's correct operation. If you need more help or links to the Briggs help (under FAQ), then post back.
Most Briggs OHV engines are set at 1/4" past TDC on the power stroke. Many adjust them at TDC (with both valves closed), but for the sake of the compression release (works off the cam), Briggs specifies 1/4" below TDC on Power Stroke.
Posted on Jun 05, 2011
Testimonial: "Awesome help. Very fast at answering and easy to understand instructions"
Installed new starter a week ago , now the starter is turning but not engaging flywheel
Check cable nut for loose or dirty. Check voltage with key turn to start,
Jun 07, 2016 | Garden
Ariens st1032
Hello Glen, I suggest you remove the flywheel cover and inspect the teeth on the starter drive and flywheel. Some engines have plastic teeth and do not hold up well to wear and may even break off. Another problem could be the starter drive may be stuck and not engaging the flywheel.
Sep 01, 2013 | Garden
Starter wont engage
either the starter is not kicking out its gear to meet the flywheel or the flywheel has missing teeth. either way the next step is to remove the starter so it can be tested outside of the vehicle and the flywheel can be looked at through the hole where the starter sat.
Mar 05, 2013 | 1987 Ford Ranger
Have 2 problems with my 2006 Toro lawn mower model 20070. I have used a total of 15 times and don't understand how it could fail with so little usage? 1) The engine will start with the cord but not...
The starter gears engage the bottom of the flywheel when starting the mower with the electric start if you can see that some of the teeth on the flywheel are stripped , you definitely need a new flywheel, parts diagram shows that it has a 'plastic ring' gear on the flywheel and doesn't show that the part is available seperate. Below is a picture of the assembly. About the running condition of the mower, I would start by removing the carburetor and cleaning it, get a common twist tie and remove the outer paper so you have a bare wire, use that wire to clean out the small hole in 'brass bowl nut' located on the bottom of the carburetor, then dry out with compressed air. The diagram below also shows the carburetor.
http://www.partstree.com/parts/?lc=toro_consumer&mn=20070%2C+22in+Recycler+Lawnmower%2C+2006+%28SN+260000001-260999999%29&dn=3355261A-378416-00013
Sep 24, 2011 | Garden
I have a husqvarna self-propelled lawn mower/keystart with leaf bag. i hit a small tree root and now it wont start. the cord back fires a little when you pull it. will a bent blade stop it from cranking?
Hi hardister2...
Sounds like you sheared the key that holds the flywheel to the crankshaft, this is a common occurance when you hit something hard with the mower running.
You will have to remove the flywheel to replace the key.
No a bent blade will not stop the mower from running,but should always be replaced
It can cause problems later with the seal under the mower, it will start to leak oil.
Please take time to rate me
Jun 28, 2011 | Husqvarna Garden
I replaced the starter on a 1994 toyota camry. Everything appears to be reconnected correctly, but all I can year when I turn the key is the sound of the starter turning. I assume it isn't engaging...
when the ignition switch is turned to the starting postion the motor should turn over if it dont then the starter is either not installed properly or the starter drive is sticking or bad if the starter is not engaging with the flywheel there could be a good chance that the teeth on the flywheel are broke off. i would pull the starter back off and use a mirror to check the teeth on the flywheel.
Dec 13, 2010 | 1994 Toyota Camry
Grinding when starting, replaced starter one month ago engages well sometimes, but now will not engage flywheel could the flywheel teeth be worn or broken?
The flywheel is worn in that specific area. Engines tend to stop in the same one or two positions, and it is those teeth that get cachunked every time you turn the key. This is ok if the bendix does a good job of threading the gear into the flywheel teeth, but the problem is that now that the teeth are half worn away, the starter attempts to mount its gear to the teeth, but before the gear is fully seated, the contacts in the motor make, the motor starts to turn, and the not-yet-seated gear bounces off of the flywheel teeth. This is what causes the teeth-grinding sound (your teeth grinding in your mouth too!) when you turn the key. . There are two solutions: The first is to, of course, replace the ring gear. . The second is hard to explain, but a good starter rebuild center (if there is such an accessible animal around anymore) will know what I'm talking about: The starter gear must have the lagging edge of each tooth ground so that each tooth will look like a chisel. The "pushing" side of each tooth must be straight and come to the point (and not be beveled). The "non-pushing" lagging side of each starter tooth should have the bevel ground in on that side. This grinding is done easily by a small angle grinder or a Dremel Tool with a cutoff wheel. . This does one thing: It assures that the gear will "spin in" without bouncing. If ground correctly (it's not hard to do), you will get successful starts every time. This is a common fix for Toyota 4-cyl with this horrible all-too-common problem. Good luck.
Nov 25, 2009 | 1987 Chevrolet S-10 Pickup
When i try to start it just clicks
SOUNDS LIKE PROBLEM IS IN THE TOP COVER AND NOT ENGAGING FLYWHEEL WHEN PULLING CHORD. I THINK ITS A PLASTIC HOUSING THE ROPE IS IN. PROBABLY STRIPPED OUT TEETH. PULL TOP COVER OFF AND LOOK UNDERNEATH FOR DAMAGE. TAKE TO LOCAL SMALL ENGINE MOWER SHOP,NOT HOME DEPOT THIS IS A SPECIFIC PART. THEY CAN ORDER YOU ONE,NOT TOO EXPENSIVE. THEY SHOULD SHOW YOU HOW TO WIND SPRING UP AND REINSTALL ROPE. ALSO LOOK AT SPRING ACTIVATED CATCHES THAT LOCK TO TETH TO ENGAGE ROTATION,MAKE SURE THOSE ARE GOOD TO
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
Cranks fine, won't "catch"
From what u describe, I believe u have a starter and possibly a flywheel problem. When u turn the key to start the car, the starter gear engages w/ the flywheel, turning the flywheel, which turns the engine over. It sounds like the teeth of the flywheel and starter are worn, (they should mesh together smoothly) which would make the grinding noise u describe. If this is the case, the flywheel and starter would need to be replaced, and its a labor intensive job, as engine and trans. have to be separated to remove/install the flywheel. The rrrrrrr sound could be the starter gear spinning but not engaging. The starter gear extends on a shaft, then engages the flywheel. It is possible the gear isn't moving forward on the shaft, just spinning w/out engaging, making the rrr sound. So, I would recommend u remove the starter and have it tested (many parts stores will do this for free) and check the teeth on the gear to see if they are worn or broken. U will also be able to see a portion of the flywheel after the starter is removed, and u should check the teeth on it also. Let me know what u find, hopefully it's just a starter problem, and the flywheel is ok.
Dec 30, 2008 | 1991 Buick Skylark
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
15 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
