Question about Nikon D90 Digital Camera with 18-105mm lens
How to set self timer for D90 - Nikon D90 Digital Camera with 18-105mm lens
    Novelist:
    Scholar:
  • Nikon Expert
  • 197 Answers
Instructions for this are on Page 179 of the D-90 users manual. First go to the menu and select the custom settings menu then scroll down to "timers/AF Lock."
Select this then select the number of shots you want the camera to take at one time on the self timer setting. Exit the menu.
Then go to the top of the camera and find the little button to the right of the control panel which contains a series of stacked rectangles.
Depress this button (camera must be on) and the control panel will clear. Rotate the wheel on the back of the camera while holding the button down until you see a little clock symbol.
If you have set it in the menu to take only one shot, you will see only the little clock. If you have set it to take multiple shots you will see the series of stacked rectangles next to the little clock.
Depress the shutter fully then walk or run to get in the picture. Just before the picture shoots, the autofocus light will flash warning you that the picture is about to be taken. The camera will shoot in the amount of time you have selected in the menu.
If you want to shoot another delayed shutter picture, repeat the procedure using the button and wheel.
Posted on Jul 14, 2014
2 Suggested Answers
jrcolbert
  • 73 Answers
SOURCE: Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Posted on Mar 06, 2009
Hi, I am trying to use the self timer function on my Nikon D90 but it doesn't seem to work. I have checked on many sites how to use it, but whenever I press the self timer button and turn the roll left...
The button for this is on the right, the second one from the rear and it has multiple squares on it for a symbol. Pressing and holding this button down then turning the rear dial should change the shutter release function. It cycles through single shot, multiple shots low and high speed, and then self timer. You set the actual parameters of the self-timer from the custom setting menu.
Dec 27, 2010 | Nikon D90 Digital Camera with 18-105mm...
How to set the timer on the nikon D 90 digital camera
Press and hold the release mode button on the top of the camera (marked with overlapping rectangles), then turn the main command dial (on the back) until the self-timer symbol (one-handed clock) appears on the command panel.
Start the self-timer by pressing the shutter release button.
To turn off the self-timer, repeat the above process to get back to single-frame, continuous low or continuous high mode.
Dec 25, 2010 | Nikon D90 Digital Camera with 18-105mm...
How do i get the timer setting on my camera?
Press and hold the shooting mode button (to the right of the display panel on top, marked with overlapping rectangles) and turn the command dial on the back to change shooting modes. The self-timer is the one with a one-handed clock. (And just the one-handed clock. Don't select the one with the one-handed clock and a rectangle representing the remote control.)
Nov 29, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon ML-L3 set up for Nikon D90?
Set the camera's release mode to one of the two remote modes. Quick-response remote mode fires the shutter when you press the button on the release, while delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To change the camera's release mode, hold down the release-mode button to the right of the LCD panel on the top of the camera (marked with the overlapping rectangles) and turn the command wheel on the back of the camera. The icon at the top-right corner of the LCD panel will change. The quick-response remote mode is indicated by a picture of the remote, the delayed remote mode is indicated by both the remote and the self-timer (one-handed clock).
Nov 09, 2010 | Nikon D90 Digital Camera with 18-105mm...
I just bought a new NIKON D90, and the self-timer doesn't work on the camera. Has anyone who bought this product had this problem?
Having gone over a month with no response on the continuous shooting mode, I assume this is no longer a problem.
Jun 27, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 only takes one photo even in continous high mode
You have to set the drive mode to H for continuous High.
The button is on the top of the camera next to the LCD.
It has an icon of overlapping rectangles.
It sets S (single frame), L (continuous Low), H (continuous High), Self Timer and Remote Control.
Just press it again until S is shown to get back to single frame.
Jan 13, 2010 | Nikon D90 Digital Camera with 18-105mm...
This website
Morris
Brooks
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
