Samsung wf8604nfs washing machine won't drain or spin flashing sud
2 Suggested Answers
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I have a samsung and the light is flashing suds, what is that?
Likely there will be crud in the hose between the tub and drain pump. Or if tub has a basket like filter attached to it the crud will be there. There are videos on youtube that explain how to perform the procedure. To find them type, for example " Samsung front load drain pump " if it's a front loading machine that is, into the youtube search bar. Hope this helps.
Jan 14, 2013 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Washer won't drain, rinse or spin
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
Will not spin after a wash or if set on the spin cycle. the suds display flashes
Check for a kinked drain hose suds means that there is too much water/soap left in after a certain time
Dec 16, 2010 | Maytag Washing Machines
Washing machine flashing de
I haven't seen a DE is it maybe DC? these are the known codes
DL - Door unlocked when washer is running DS - Door is open when washer is running NF - Washer tried to fill but was not successful due to clogged water lines or closed water valves. ND - Washer is not draining it can also mean that the unit senses a small clog or frozen hose. DC - Unbalanced load prevented the washer from spinning. When the weight of the laundry is about 1kg the center of the weight gets shifted. redistribute the load and restart or add more clothing.
SUDS - Too many suds are detected, the unit will be put on hold until the suds are reduced the it will go back on. when it completes the wash it will flash END and SUDS. make sure you use HE (high efficiency) detergent
Oct 10, 2010 | Samsung Washing Machines
Kenmore elite HE3 front load washer won't drain or spin and displays sud and flashes FO2
Hi there
I have found this and i hope this gets you in the right direction. Merry X-mas and Happy New Year also.
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Thank you for writing to Fix Ya.
Best regards Richard
Dec 15, 2009 | Washing Machines
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
