Question about Canon PowerShot SD20 / IXUS i5 Digital Camera
Overexposed pictures and white horizontal lines
Pictures from macro mode are overexposed even i turned the exposure compensation to -2.
  • 2 more comments
  • dannycumb Nov 15, 2007
    Same problem but all photos, not just macro. I really just want the camera cause i have the underwater casing for it wchich is magic
  • Anonymous Jul 01, 2008
    I have the same problem too:-
    Pictures turn to white on sunny day even though i set the exposure to -2
  • damned_dle Feb 20, 2009
    i have exactly the same problem as dannycumb's. can anyone please HELP!!
  • Dan Frazier
    Dan Frazier Apr 07, 2014
    I'm not an expert on these cameras, but I have had the same problem with the Canon Powershot A460. (images look overexposed with horizontal lines appearing in the images). I think this is probably a sensor problem. It might be caused by moisture getting in the camera, dropping the camera, or other factors, like static electricity or simply the age of the camera. I'm guessing that it would be expensive to repair. I notice on my camera that the video function seems to work fine. The video uses a low-resolution setting. So I took a test still picture using the low resolution setting "S" instead of M1, M2 or L. My test looks pretty good. So rather than throwing the camera away, I am likely to save it for low-resolution pictures and video use.
I also having this problem white horizontal lines ...any solution?
If repair how much around?Please help!
Posted on Sep 02, 2008
Have the same problem here. I found the problem caused by the broken ribbon cable that connecting the lens shutter, lens cover motor to the mainboard of the camera. No luck finding the replacement part so far. If anyone know where to get the part please post it here. Thanks.
Posted on Apr 19, 2010
SOURCE:
Www samsungcamera com
It seems to me that the camera is overexposing the images.
First make sure that the 'ISO' is set to a lower value such as 100 or 200. Also ensure that the Exposure Compensation (+/-) is set to '0'. For this, you might need to put the camera on 'P' mode.
Aug 25, 2014 | Samsung L73 Digital Camera
My canon powershot g12 lcd works fine but the photos are all 'whited' out
You may have the exposure compensation settings overexposing you images. Since it compensates without affecting the image prior to shooting, you won't see it until after the image is taken. Check that and the flash exposure compensation too.
Jun 21, 2014 | Canon G12 Digital Camera
All of a sudden the images my camera is taking look totally overexposed, is it possible that i switched some setting without knowing? why is there so much light in my pictures?
Yes, there is a setting called exposure compensation, which you may have altered.
Try switching the camera back to A (Auto) mode, and see if that fixes it.
In the manual setting modes, exposure compensation will look like this:
http://images.digitalcamerainfo.com/images/upload/Image/new/Photokina08/Canon/sd880is/photos/Canon-sd880is-menu-functionset-375.jpg
Make sure that you haven't set the exposure compensation to +2, for example. It should usually be set on 0.
Mar 03, 2011 | Canon PowerShot A590 IS Digital Camera
My nikon d40 shot results contains white space from upper part, sometimes almost half of the picture, and now the whole picture frame is all white. what is the problem with my camera? is the shutter...
What mode are you shooting in? if in manual, your shutter speed is to slow and your photos are probably overexposed. or if you are in one of the program modes you probably have exposure compensation turned up very high. so turn down your exposure compensation down by holding the button that has a plus and a minus on it and turn so that it is set to 0
Feb 28, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
My Canon Rebel XT is overexposing shots in the Auto and Program mode by 1 or 2 stops. How do I fix this or compensate for it?
You can go into "exposure compensation" and lower the setting as you desire. It's the button that's half-black/half-white with a plus and minus.
Oct 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Pictures white out; pictures are completely overexposed; I've had this problem with Casio cameras before; The video capacity works fine, it just can't take any clear pictures. All pictures come out...
Check the exposure compensation setting:
  • In REC mode, press MENU
  • Select the "Quality" tab and select "EV-Shift"
  • Set the exposure compensation value to zero.
If this doesn't help, please post a sample picture (e.g. upload an unedited full size image to http://imageshack.us/ and post the link as a comment).
Mar 29, 2010 | Casio Exilim EX-S600 Digital Camera
Canon 350d with sigma 75-300 Macro
Check you exposure compensation and make sure it's not set above 0. Also take a peek at your LCD brightness level. If it's set high, everything looks overexposed when it's really not.
Sep 03, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Canon Powershot S330 Picture Brightness Help!!!
It sounds like the camera exposure system is out of whack and may need to be serviced. You may want to ensure that exposure compensation is set to 0. Check one of your overexposed images with the display in the 'Detailed Display' mode (two lines of information at the bottom of the LCD). If the second item on the top line is not ±0, the exposure compensation is not at its default value. To set, put the camera in M(anual) shooting mode. Press the Exposure/White Balance button until you see a scale along the bottom of the LCD from -2 to +2. Use the left or right button to set it at 0. If the value is already at 0, you will probably need service.
Apr 28, 2008 | Canon PowerShot S330 / IXUS 330 Digital...
With Macro flash unit attached, and using the closest subject distance, images are extremely over-exposed.
The camera fails to control the flash output automatically due to the high intensity of Macro ring flash, causing the image to be over-exposed. Please set the camera as below to prevent a undesired result. Camera and Flash Settings - Set the sensitivity to ISO 100 using the function dial of the camera. - Set the flash metering of the camera to Pre-Flash TTL from the recording-mode menu. MACRO RING FLASH 1200 - Set the camera exposure mode to A or M mode. - Set the aperture to f/6.7. - Attach a ND filter x4 (0.6D) to the camera lens. MACRO TWIN FLASH 2400 - Attach a diffuser to the flash tube units. In case the flash tube and the subject is too close, eg. Not using the arms, set the camera exposure mode to A or M mode and the aperture to f/6.7. A subject at minimum distance may still be overexposed. Use exposure compensation to obtain the best result.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Canon PowerShot SD20 / IXUS i5 Digital Camera Logo
519 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
