Question about Skil 15-Amp 10" Table Saw 3310-01
2610012961 Good day ... I need the motor (2610012961) or engine parts. Intended to skil saw 3310 Thanks. Tony brazrosewood@gmail.com
5 Suggested Answers
  • 33 Answers
SOURCE: Skil saw motor runs but blade won't spin
The key could be sheared in the final drive shaft as well.
Posted on Jul 25, 2009
jyackle5
  • 8197 Answers
SOURCE: will the skil 80092 table saw stand accomodate the
Yes it will hold the Bosch 4000 with a little modification.
Posted on Mar 02, 2010
Testimonial: "Do you know what modifications i would have to make ? It would be of great help to know what i'm getting into before i purchase the stand!! Thanks "
SOURCE: I own a old 10
http://www.toolpartsdirect.com/skil/skil-34.html
http://www.ereplacementparts.com/skil-parts-c-130.html
try these people above, ANY switch, that has the same physical size, has the same Voltage/Current rating will work.
FYI below... http://www.skiltools.com/en/CustomerService/FAQs/#%7BA0946D17-4368-4CCE-972C-3E61DB3337A2%7D
Posted on Nov 25, 2010
SOURCE: where is the jam nut located on a skil saw table saw 3310
I called skil & they emailed the pictures taken by the techs. Not sure why they don't have the pictures on their frequently asked questions part of their site.... seems like if they took the time to take the picture, they would know it is going to be a frequently asked question... lol.
Posted on Nov 29, 2012
The blade on my new skil 3310 won't raise. It came preassembled & has never been used, but the elevation wheel feels locked. I can adjust the angle, but turning the knob doesn't raise/lower blade.
Just as a question and I am not being smart you know that the wheel to raise the blade work counter clockwise.
The other thing you need to check is in your manual here is the part how to adjust the blade for raisin/lowering.
After five hours of operation, the blade elevation/tilting mechanism should be checked for looseness, binding, or other abnormalities. Disconnect the saw from the power source, turn the saw upside down and pull up and down on the motor unit. Observe any movement in the motor mounting mechanism. Looseness or play in the blade raising screw 1 should be adjusted as follows (Fig. 55): 1. Loosen nut 2. 2. Adjust the nut 3 until it is finger-tight against the bracket 4, then back off the nut 3 1/6 turn. 3. Tighten nut 2. The maximum allowable play of the screw rod 1 is 5/32" (4 m). Place a small amount of dry lubricant (such as graphite or silicon) on the screw rod 1 at the thrust washer 5. Do not oil the threads of screw rod 1. The screw rod 1 must be kept clean and free of sawdust, gum, pitch, and other contaminant's for smooth operation. NOTE: If excessive looseness is observed in any other part of the blade elevation mechanism or tilting mechanism, take the complete unit to an authorized service center.
Oct 21, 2015 | Skil Saws
How do I install new brushes on 15 amp motor for 3400 skil table saw?
http://www.ereplacementparts.com/skil-3400-f01234000a-table-saw-parts-c-130_164_7498.html
Here is the breakdown - I believe the brush tubes just friction fit with the wire connected by a spade terminal.
Jan 14, 2015 | Skil Saws
Where is the jam nut located on a skil saw table saw 3310
Aug 23, 2012 | Skil Saws
Motor runs, saw not cutting
Hi
If motor is running and the blade is not turnning the motor pinion gear is damage.
Go see this link for parts diagram.
http://www.ereplacementparts.com/skil-5500-f012550000-714-circular-saw-parts-c-130_160_843.html
Feb 07, 2011 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
I need a parts/repair manual for skil 6 1/2" circular saws model numbers 552&536.
Hello ray....... the parts and repair manuals are available directly from the Skil company. Here is the link http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
You may also find the parts diagrams, parts numbers and parts themselves at Searspartsdirect.com
Joe
Thanks for choosing Fixya!
Jan 22, 2011 | Garden
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Nokia3310 sound problem
you need to open your cell phone. clean the riger contacts if not then check the ringer buzzer if it is ok, check it with a multi tester. and lastly make this jumpering
Dec 07, 2008 | Nokia 1100
Skil 15-Amp 10" Table Saw 3310-01 Logo
101 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
