Question about Dishwashers
Daniela dishwasher No washing fault (E1)
4 Suggested Answers
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
Richie_asg1
  • 1036 Answers
SOURCE: E1 fault code Dishwasher runs for
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Posted on Aug 05, 2009
SOURCE: e1 fault no manual
Hi, use this table to find and know more about codes.When you get into the link,scroll you will see all codes and solution.
(repairclinic.com/0078.asp).
Take care.
Posted on Jun 14, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
    LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
    The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
    Sep 25, 2015 | LG Dishwashers
    HOW TO CLEAR CODE E1 ON LG DISHWASHER ?
    The 1E error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
    Jun 13, 2014 | LG LDF7561ST FulIntegrated Dishwasher with...
    F&P Dishwasher Fault
    Most likely you have fault code E1 which means door is not shut properly. It is likely the door springs need adjustment as the door might be opening mid cycle.
    Refer manual
    http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/599350D_DW60ugm_AUSGw.pdf
    Mar 18, 2014 | Fisher and Paykel Dishwashers
    What fault is E1
    it means excessive r.p.m.'s of the wash motor during a wash cycle due to water leakage due to a leaking drain hose,the drain hose is not over 20" to the drain,a broken pump impeller,a damaged motor water sump seal
    Nov 18, 2010 | LG Dishwashers
    E1 fault no manual
    Take care.
    Jun 14, 2010 | LG 24 in. LD-12BW5 Free-standing...
    Kenwood dishwasher showing e1
    fault E1 in manual states no inlet pressure. sometimes fault code shows if machine takes too long to fill. check for blockage in inlet pipe.
    May 09, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
    E1 fault code Dishwasher runs for about 5 minutes. Water fills up at bottom of unit and then machine seems to pause then fault code E1 appears then water is pumped out from bottom of machine. There are...
    Aug 05, 2009 | Dishwashers
    E1 fault on kenwood dishwasher kdw243a
    error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
    Jan 18, 2009 | Kenwood KW85 Air Conditioner
    Lg dishwasher model LD - 14AT2
    E1 is usually a very common fault of the wash motor not working.
    The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
    There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
    The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
    Hope this helps.
    Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
    Dishwashers Logo
    89 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
